The ThinkCentre M900 small form factor come in a sleek ID, offering enterprise-level performance with powerful processor. The desktops also feature the ThinkCentre Dust Shield, a unique Lenovo solution, that reduces dust intake, reducing maintenance and extending the life of the machine. The SFF is smaller, delivering robust protection for your critical data. For enhanced features the M900 offers PCI slot for expansion.
Product Description | Lenovo ThinkCentre M910s - SFF - Core i7 7700 3.6 GHz - vPro - 8 GB - SSD 256 GB - UK | Type | Personal computer - small form factor | Platform Technology | Intel vPro Platform | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i7 (7th Gen) 7700 / 3.6 GHz (, up to 4.2 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 8 MB | Cache Per Processor | 8 MB | RAM | 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB - PCI Express 3.0 x4 - M.2 - NVM Express (NVMe) | Optical Storage | DVD-Writer | Graphics Controller | Intel HD Graphics 630 | Networking | 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | Cyberlink PowerDVD, Lenovo Companion, Intel Unite, PowerDVD Create, Lenovo ID | Colour | Black | Dimensions (WxDxH) | 9.25 cm x 29.05 cm x 34.35 cm | Weight | 5.4 kg | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Built-in Devices | Speaker |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7700 |
Clock Speed | 3.6 GHz |
Max Turbo Speed | 4.2 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel Q270 |
Cache Memory | |
Installed Size | 8 MB |
RAM | |
Installed Size | 8 GB / 64 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | DIMM 288-pin |
Slots | 4 (Total) / 3 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD - M.2 |
Capacity | 1 x 256 GB |
Interface Type | PCI Express 3.0 x4 |
Features | NVM Express (NVMe) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 4 |
Optical Storage | |
Type | DVD-Writer - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | VGA, DisplayPort |
Max Monitors Supported | 3 |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Interface | USB |
Networking | |
Interface (Bus) Type | M.2 Card |
Ethernet Controller | Intel I219-LM |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 8265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1 |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 3.5" x 1/3H |
Slots | 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x1 - low-profile , 2 (total) / 0 (free) x M.2 Card |
Interfaces | 8 x USB 3.1 Gen 1 (4 front, 4 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 2 x DisplayPort , 1 x audio line-in , 1 x audio line-out |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3 |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 210 Watt |
Efficiency | 85% |
Operating System / Software | |
Software | Cyberlink PowerDVD, Lenovo Companion, Intel Unite, PowerDVD Create, Lenovo ID |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 6.1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
Dimensions & Weight | |
Width | 9.25 cm |
Depth | 29.05 cm |
Height | 34.35 cm |
Weight | 5.4 kg |
