Lenovo ThinkCentre M910z AIO is built for enterprise. M910z AIO enables you carry out intensive task with ease. Plus built-in data security - these easy-to-use machines keep your workforce on task, and improve productivity.
Product Description | Lenovo ThinkCentre M910z - all-in-one - Core i5 7400 3 GHz - 4 GB - HDD 500 GB - LED 23.8" - UK | Type | Personal computer - all-in-one | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i5 (7th Gen) 7400 / 3 GHz (, up to 3.5 GHz, (Quad-Core) | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | HDD 500 GB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD-Writer | Card Reader | 9 in 1 | Monitor | 23.8" - LED - 1920 x 1080 (Full HD) - 16:9 | Graphics Controller | Intel HD Graphics 630 | Camera | Yes | Networking | 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Colour | Business black | Dimensions (WxDxH) | 58.4 cm x 24.5 cm x 45.8 cm | Weight | 8.8 kg | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | All-in-one - with Basic Stand |
Built-in Devices | Stereo speakers |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7400 |
Clock Speed | 3 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Chipset Type | Intel Q270 |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 500 GB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | DVD-Writer - SATA |
Card Reader | |
Type | 9 in 1 card reader |
Monitor | |
Monitor Type | LED |
Diagonal Size | 23.8" |
Native Resolution | 1920 x 1080 (Full HD) |
Widescreen Display | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 250 cd/m² |
Image Contrast Ratio | 1000:1 |
Monitor Features | Anti-glare, Low Blue Light Mode, Wide Viewing Angle |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | DisplayPort |
Audio Output | |
Compliant Standards | High Definition Audio, Dolby Audio |
Speakers Included | 2 x right / left channel |
Camera | |
Camera | Yes |
Resolution (MP) | 2 Megapixel |
Resolution | 1080p |
Features | Built-in 2 microphones, LED indicator |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Intel I219-LM |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 8265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1 |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Slots | 2 (total) / 1 (free) x SO-DIMM 260-pin , 2 (total) / 1 (free) x M.2 Card |
Interfaces | 6 x USB 3.1 Gen 1 (2 front, 4 rear) (one of them is Always On and fast-charging) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort input/output combo |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), chassis intrusion switch |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | 100 x 100 mm |
Compliant Standards | RoHS, GREENGUARD, UL Environmental SPC Gold, Energy-Related Products (ErP) Lot 3 |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 150 Watt |
Efficiency | 85% |
Operating System / Software | |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 6.1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
Dimensions & Weight | |
Width | 58.4 cm |
Depth | 24.5 cm |
Height | 45.8 cm |
Weight | 8.8 kg |
