Is it better to be powerful or mobile? With the new ThinkPad P1, the answer is... both. No need to choose. It's thinnest and lightest mobile workstation ever at 18.4mm and 1.7 kg. But it still delivers on power with 8th Gen Intel Xeon and Core processors, NVIDIA Quadro graphics, and massive memory and storage options.
Product Description | Lenovo ThinkPad P1 - 15.6" - Intel Core i7 - 8750H - 16 GB RAM - 256 GB SSD - UK | Product Type | Mobile workstation | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i7 (8th Gen) - 8750H / 2.2 GHz, up to 4.1 GHz / 9 MB Cache | Memory | 16 GB DDR4 (2 x 8 GB) | Storage | 256 GB SSD - TCG Opal Encryption 2, NVMe | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro P1000 / Intel UHD Graphics 630 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, TrackPoint, UltraNav | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet | Battery | Up to 13.87 hours | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Black | Dimensions (WxDxH) | 36.18 cm x 24.57 cm x 1.84 cm | Weight | 1.7 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Specific Absorption Rate (SAR) | 0.193 W/kg (body) , 0.193 W/kg (limb) | Manufacturer Warranty | Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8750H / 2.2 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | 6-core |
Cache | 9 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM246 |
Features | Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 16 GB (2 x 8 GB) |
Max RAM Supported | 64 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2666 MHz |
Rated Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 0 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe) |
Display | |
Type | 15.6" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Colour Gamut | 72% |
Features | Anti-glare |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA Quadro P1000 / Intel UHD Graphics 630 |
Camera | Yes - 720p |
Camera Features | ThinkShutter camera privacy |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3286 |
Compliant Standards | High Definition Audio, Dolby Audio Premium, Dolby Atmos |
Input | |
Type | Keyboard, TrackPoint, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad, buttonless touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 5.0 |
Wireless Controller | Intel Wireless-AC 9560 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Battery | |
Technology | Lithium Ion |
Capacity | 80 Wh |
Run Time | Up to 13.87 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 135 Watt |
Connections & Expansion | |
Interfaces Details | USB 3.1 Gen 1 (Always On) , USB 3.1 Gen 1 , 2 x USB-C (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , LAN (on supplied cable) |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC UHS-II Card) |
Miscellaneous | |
Colour | Black |
Case Material | Aluminum, glass-fibre reinforced plastic, carbon fibre reinforced plastic |
Features | Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter, ThinkPad Ethernet Extension cable |
Compliant Standards | RoHS |
SAR Value | 0.193 W/kg (body), 0.193 W/kg (limb) |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.7 kg |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year |
