Enjoy the rich, full audio of this workstation's stereo speakers to immerse you in sound. Plug in with your headphones and experience enhanced Dolby Atmos enabled audio. Additionally, the dual far-field microphone ensures you'll be heard clearly on every call.
Product Description | Lenovo ThinkPad P73 - 17.3" - Intel Core i7 9750H - 16 GB RAM - 512 GB SSD - UK | Product Type | Mobile workstation | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i7 (9th Gen) 9750H / 2.6 GHz (4.5 GHz) / 12 MB Cache | Memory | 16 GB DDR4 (2 x 8 GB) | Storage | 512 GB SSD - TCG Opal Encryption 2, NVMe | Display | 17.3" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro T2000 / Intel UHD Graphics 630 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, TrackPoint, UltraNav | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac/ax, Bluetooth 5.1, Gigabit Ethernet | Battery | Up to 10 hours | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Black | Dimensions (WxDxH) | 41.6 cm x 28.1 cm x 3.1 cm | Weight | 3.4 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i7 (9th Gen) 9750H / 2.6 GHz |
Max Turbo Speed | 4.5 GHz |
Number of Cores | 6-core |
Cache | 12 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM246 |
Features | Integrated memory controller |
Memory | |
RAM | 16 GB (2 x 8 GB) |
Max RAM Supported | 128 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2666 MHz |
Rated Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 4 |
Empty Slots | 2 |
Storage | |
Main Storage | 512 GB SSD M.2 2280 PCIe 3.0 x4 - TCG Opal Encryption 2, NVM Express (NVMe) |
Display | |
Type | 17.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Colour Gamut | 72% |
Features | Anti-glare, 160° viewing angle |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA Quadro T2000 / Intel UHD Graphics 630 |
Camera | Yes - 720p |
Camera Features | IR camera, ThinkShutter camera privacy |
Sound | Stereo speakers, dual array microphone |
Codec | Conexant CX11880 |
Compliant Standards | High Definition Audio, Dolby Atmos |
Input | |
Type | Keyboard, TrackPoint, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac/ax, Bluetooth 5.1 |
Wireless Controller | Intel Wi-Fi 6 AX 200 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Battery | |
Technology | Lithium Ion |
Capacity | 99 Wh |
Run Time | Up to 10 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 170 Watt |
Connections & Expansion | |
Interfaces | USB 3.1 Gen 1 (Always On) , 2 x USB 3.1 Gen 1 , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , 2 x USB-C 3.1 Gen 1 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , HDMI , LAN , Headphone/microphone combo jack |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Miscellaneous | |
Colour | Black |
Case Material | Glass-fibre reinforced plastic, magnesium-aluminum alloy, polyphenylene sulfide |
Features | Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 3.4 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year |
Get more from your purchase from one of our essential accessories
