The definition of versatility, this ultralight 2-in-1 adapts to your business with 4 flexible modes to work, present, create, and connect. It features a stunning display with intense color and deep contrast.
Product Description | Lenovo ThinkPad X1 Yoga (3rd Gen) - 14" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD - 4G LTE-A - UK | Product Type | Notebook - flip design | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD - TCG Opal Encryption 2, NVMe | Display | 14" LED backlight touchscreen 2560 x 1440 / WQHD | Graphics | Intel UHD Graphics 620 | Input Device | Digitizer, TrackPoint, digital pen, UltraNav | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, NFC, Bluetooth 4.1, Gigabit Ethernet | Wireless Broadband (WWAN) | 4G LTE Advanced | Service Provider | Not specified | Battery | 4-cell - up to 15.4 hours | Features | Ambient light sensor, 3-axis gyro sensor, 3-axis accelerometer | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Colour | Black | Dimensions (WxDxH) | 33.3 cm x 22.9 cm x 1.705 cm | Weight | 1.4 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified EPEAT Silver | Specific Absorption Rate (SAR) | 1.372 W/kg (body) , 1.372 W/kg (limb) | Manufacturer Warranty | Limited warranty - 3 years - on-site |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8250U / 1.6 GHz |
Max Turbo Speed | 3.4 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 2133 MHz |
Rated Speed | 2133 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe) - Samsung |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 2560 x 1440 (WQHD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Colour Gamut | 72% |
Features | Anti-reflective, anti-smudge |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Camera | Yes - 720p |
Camera Features | ThinkShutter camera privacy |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3286 |
Compliant Standards | High Definition Audio, Dolby Audio Premium |
Input | |
Type | Keyboard, digitizer, TrackPoint, digital pen, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, NFC, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Wireless Broadband (WWAN) | |
Generation | 4G |
Technology | LTE Advanced |
Controller | FIBOCOM L850-GL - M.2 Card |
Navigation | |
Receiver | GPS |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 54 Wh |
Run Time | Up to 15.4 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 20 V, 3.25 A |
Connections & Expansion | |
Interfaces Details | USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , LAN (on supplied cable) |
Memory Card Reader | Yes (microSDXC UHS-II) |
Miscellaneous | |
Colour | Black |
Case Material | Carbon fibre, glass-fibre, magnesium alloy, polyphenylene sulfide |
Integrated Options | Ambient light sensor, 3-axis gyro sensor, 3-axis accelerometer |
Features | Administrator password, hard drive password, power-on password, MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | ThinkPad Pen Pro, ThinkPad Ethernet Extension cable, USB-C power adapter |
Compliant Standards | RoHS |
SAR Value | 1.372 W/kg (body), 1.372 W/kg (limb) |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.4 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
Get more from your purchase from one of our essential accessories
