Power, performance, and portability - that's what you get with the ThinkPad X270. A fast processor and plenty of storage and memory ensure you'll never be waiting on apps to load or the system to boot. The X270 is destined to give your business the edge.
Product Description | Lenovo ThinkPad X270 - 12.5" - Intel Core i5 - 7300U - vPro - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Platform Technology | Intel vPro Platform | Processor | Intel Core i5 (7th Gen) - 7300U / 2.6 GHz, up to 3.5 GHz / 3 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 256 GB SSD - TCG Opal Encryption 2, NVMe | Display | 12.5" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 620 | Input Device | TrackPoint, UltraNav | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 3-cell - up to 13.04 hours | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Black | Dimensions (WxDxH) | 30.55 cm x 20.85 cm x 2.03 cm | Weight | 1.36 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7300U / 2.6 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Rated Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 0 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe) |
Display | |
Type | 12.5" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 200 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 720p |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3268 |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, TrackPoint, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad, buttonless touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Wireless Broadband (WWAN) | |
Generation | WWAN upgradable |
Battery | |
Technology | 3-cell Lithium Ion |
Installed Qty | 2 |
Capacity | 23 Wh |
Run Time | Up to 13.04 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt |
Connections & Expansion | |
Interfaces Details | USB 3.1 Gen 1/USB 3.0 , USB 3.1 Gen 1/USB 3.0 (Always On) , USB-C 3.1 Gen 1 (Power Delivery 2.0) , HDMI , LAN , Dock , Headphone/microphone combo jack |
Memory Card Reader | 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card) |
Software | |
Software Included | Lenovo Companion, Lenovo Settings |
Miscellaneous | |
Colour | Black |
Case Material | Glass-fibre reinforced plastic |
Dockable | Yes |
Features | Administrator password, hard drive password, power-on password, Intel Active Management Technology (iAMT), MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.36 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year |
