The thin and ultralight ThinkPad X280 optimizes your journey to success. All-day battery life with RapidCharge ensures uninterrupted inspiration on the go. And whether you're in the office, at the corner cafe, you can rest assured your ideas stay yours with enhanced security features.
Product Description | Lenovo ThinkPad X280 - 12.5" - Intel Core i7 - 8550U - 16 GB RAM - 512 GB SSD - 4G LTE - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i7 (8th Gen) - 8550U / 1.8 GHz, up to 4 GHz / 8 MB Cache | Memory | 16 GB DDR4 (provided memory is soldered) | Storage | 512 GB SSD - TCG Opal Encryption 2, NVMe | Display | 12.5" LED backlight 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics 620 | Input Device | TrackPoint, UltraNav | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Wireless Broadband (WWAN) | 4G LTE | Battery | Up to 16.6 hours | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Black | Dimensions (WxDxH) | 30.77 cm x 20.98 cm x 1.78 cm | Weight | 1.13 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8550U / 1.8 GHz |
Max Turbo Speed | 4 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Features | Integrated memory controller |
Memory | |
RAM | 16 GB (provided memory is soldered) |
Technology | DDR4 SDRAM |
Speed | 2400 MHz |
Rated Speed | 2400 MHz |
Storage | |
Main Storage | 512 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe) |
Display | |
Type | 12.5" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Anti-glare |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Camera | Yes - 720p |
Camera Features | ThinkShutter camera privacy |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC3287 |
Compliant Standards | High Definition Audio, Dolby Audio Premium |
Input | |
Type | Keyboard, TrackPoint, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad, buttonless touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 - M.2 Card |
Ethernet Controller | Intel I219-V |
Features | Gigabit Ethernet via optional Ethernet (RJ-45) adapter |
Wireless Broadband (WWAN) | |
Generation | 4G |
Technology | LTE |
Controller | FIBOCOM L830-EB - M.2 Card |
Battery | |
Technology | Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 16.6 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt |
Connections & Expansion | |
Slots | Nano-SIM card |
Interfaces Details | USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , USB-C 3.1 Gen 1 , USB-C 3.1 Gen 2 (supports Thunderbolt 3) , HDMI , Lenovo Ethernet extension connector , Dock , Headphone/microphone combo jack |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Colour | Black |
Case Material | Carbon fibre |
Dockable | Yes |
Features | Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington mini security slot |
Included Accessories | USB-C power adapter |
Compliant Standards | RoHS |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.13 kg |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year |
