Combining power, performance, and portability, the stylish yet durable ThinkPad Yoga 370 gives you the freedom to work/play anywhere. Enjoy using it in different ways - from laptop to tablet and anything in between. Save time by writing, highlighting, or drawing directly on screen. Take delight in seeing your visuals, presentations, and movies come to life on the vibrant 13.3" display.
Product Description | Lenovo ThinkPad Yoga 370 - 13.3" - Intel Core i7 - 7500U - 8 GB RAM - 512 GB SSD - UK | Product Type | Notebook - flip design | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 512 GB SSD - TCG Opal Encryption 2, NVMe | Display | 13.3" LED backlight touchscreen 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Input Device | Digitizer, TrackPoint, digital pen, UltraNav | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | 4-cell - up to 12.5 hours | Features | Ambient light sensor, 3-axis gyro sensor, digital compass, 3-axis magnetometer, 3-axis accelerometer | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Silver | Dimensions (WxDxH) | 31.35 cm x 22.22 cm x 1.82 cm | Weight | 1.37 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year - pick-up and return |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7500U / 2.7 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 0 |
Storage | |
Main Storage | 512 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe) |
Display | |
Type | 13.3" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Glossy |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 720p |
Sound | Stereo speakers, dual array microphone |
Codec | CX11771 |
Compliant Standards | High Definition Audio, Dolby Audio X2 |
Input | |
Type | Keyboard, digitizer, TrackPoint, digital pen, UltraNav |
Keyboard Layout | UK |
Features | Spill-resistant, multi-touch touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 - M.2 Card |
Ethernet Controller | Intel I219-V |
Features | Gigabit Ethernet via optional Ethernet (RJ-45) adapter |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 51 Wh |
Run Time | Up to 12.5 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 20 V |
Connections & Expansion | |
Interfaces Details | USB 3.0 , USB 3.0 (Always On) , USB-C 3.1 Gen 2 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack , Lenovo Ethernet extension connector |
Memory Card Reader | Yes (microSDXC UHS) |
Software | |
Software Included | Lenovo Companion, Lenovo Settings, Lenovo Connect |
Miscellaneous | |
Colour | Silver |
Case Material | Carbon fibre |
Integrated Options | Ambient light sensor, 3-axis gyro sensor, digital compass, 3-axis magnetometer, 3-axis accelerometer |
Features | Administrator password, hard drive password, power-on password, MIL-STD-810G tested |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter, ThinkPad Pen Pro |
Compliant Standards | RoHS |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.37 kg |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - pick-up and return |
