With powerful processor and advanced memory - the Lenovo V520S small form factor is designed to boost your productivity. Combined with performance-enhancing hard drive - you have speed and power at your fingertips as you handle large files, create rich content, and stay in touch. With 4 forward-facing USB ports, you can connect your peripherals, and adapt as your business grows. Your V520S small form factor delivers security, simplicity, and productivity - helping you drive your business forward.
Product Description | Lenovo V520S-08IKL - SFF - Core i3 7100 3.9 GHz - 4 GB - SSD 128 GB - UK | Type | Personal computer - small form factor | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Hyper-Threading Technology, Intel Smart Cache | Cache Memory | 3 MB | Cache Per Processor | 3 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 128 GB - SATA 6Gb/s - 2.5" (7 mm) | Optical Storage | DVD-Writer | Card Reader | 7 in 1 | Graphics Controller | Intel HD Graphics 630 | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Software Included | Lenovo Companion, Lenovo ID | Colour | Black | Dimensions (WxDxH) | 29.05 cm x 34.35 cm x 8.9 cm | Weight | 4.75 kg | Manufacturer Selling Program | TopSeller | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year - on-site |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Embedded Security | Firmware Trusted Platform Module (TPM 2.0) Security Chip |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i3 (7th Gen) 7100 |
Clock Speed | 3.9 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel B250 |
Cache Memory | |
Installed Size | 3 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | DIMM 288-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | SSD - 2.5" (7 mm) |
Capacity | 1 x 128 GB |
Interface Type | SATA 6Gb/s |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 3 |
Optical Storage | |
Type | DVD-Writer - SATA |
Card Reader | |
Type | 7 in 1 card reader |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | VGA, HDMI, DisplayPort |
Max Monitors Supported | 3 |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | Lenovo Calliope Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Mouse Name | Lenovo Calliope Mouse |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111GN |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL) |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5" x 1/8H |
Slots | 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x1 - low-profile , 2 (total) / 2 (free) x M.2 Card |
Interfaces | 6 x USB 3.0 (4 front, 2 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x VGA , 1 x DisplayPort , 1 x HDMI |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), padlock loop |
Compliant Standards | RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3 |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 180 Watt |
Efficiency | 85% |
Operating System / Software | |
Software | Lenovo Companion, Lenovo ID |
Sustainability Information | |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 6.1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - on-site |
Dimensions & Weight | |
Width | 29.05 cm |
Depth | 34.35 cm |
Height | 8.9 cm |
Weight | 4.75 kg |
