Ultra Clear 218 PPI 5K Display
At 218 pixels per inch to deliver 5K resolution (5120 x 2880 at 27") the LG UltraFine™ 5K display lets you experience the definition and detail of a Mac on a large 5K screen.
Rich Color, Better Detail
A color spectrum of P3 99% enables you to edit your high-resolution photos precisely. You will experience exceptional detail and rich color on this 5K display.
5K Display with Thunderbolt™ 3
The LG UltraFine™ 5K display with Thunderbolt™ 3 port can transmit 5K video and data while simultaneously charging a new MacBook Pro (up to 85W) over a single cable. Plus, three USB-C downstream ports (USB 5 Gbps) let you connect additional devices as needed.
Ultimate Visibility
The LG UltraFine™ 5K display reaches a brightness of 500cd/m² and can express a wide range of color and contrast. You can experience vivid, lifelike images on a 5K screen, which provides a more natural representation.
Consistent Color and Clarity
This 5K high-definition monitor with IPS minimizes color shift and delivers detailed, accurate images on the UltraFine™ 5K screen. Color is consistent from edge to edge.
Clear Communication and Entertainment
The LG UltraFine™ 5K display has an internal webcam and responsive speakers/microphone that are perfectly suited to entertainment and communication, allowing you to watch movies, and video chat.
Easy Display Control with macOS
Detailed control of display settings such as brightness can be done using macOS without the need to use any physical buttons.
Multi-Function Screen Manager
The LG Screen Manager has been optimized for macOS to provide a variety of multi-screen options. For example, it can automatically divide the screen into two to four frames, according to users’ specific needs.
Convenient Adjustable Display Stand
LG UltraFine™ 5K displays have convenient height/tilt adjustment. Users can customize the display height to create a more personal, comfortable workstation, or easily wall-mount the display with the use of a VESA mount bracket.
Product Description | LG UltraFine 27MD5KA-B - LED monitor - 5K - 27" | Device Type | LED-backlit LCD monitor - 27" | Features | Microphone, camera, USB-C hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 5K 5120 x 2880 at 60 Hz | Pixel Pitch | 0.11685 mm | Brightness | 500 cd/m² | Contrast Ratio | 1100:1 | Response Time | 14 ms (grey-to-grey) | Colour Gamut | 99% DCI-P3 (CIE 1931) | Input Connectors | Thunderbolt 3 | Display Position Adjustments | Height, tilt | Screen Coating | Anti-reflective, 2H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Non-glossy black | Dimensions (WxDxH) - with stand | 62.56 cm x 23.99 cm x 46.44 cm | Weight | 8.5 kg | Compliant Standards | FCC Class B certified, UL, VCCI, BSMI, cUL, CCC, RoHS, REACH, KC, RCM, EPA 7.0, HDCP 2.2, HDCP 1.4 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | Microphone, camera, USB-C hub |
Panel Type | IPS |
Pixel Per Inch | 218 |
Vertical Refresh Rate | 48 - 60 Hz |
Horizontal Refresh Rate | 30 - 178 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | 4-screen split |
Dimensions (WxDxH) | 62.56 cm x 23.99 cm x 46.44 cm - with stand |
Weight | 8.5 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 5 Watt |
Connectivity | |
Interfaces | Thunderbolt 3 / USB-C , 3 x USB-C downstream |
Mechanical | |
Tilt Angle | -5/+25 |
Height Adjustment | 110 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), ambient light sensor |
Included Accessories | VESA cover |
Cables Included | 1 x Thunderbolt 3 / USB-C cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 140 Watt |
Power Consumption Sleep | 1.2 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Software / System Requirements | |
Included Software | LG Screen Manager |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 62.56 cm - depth: 23.99 cm - height: 46.44 cm - weight: 8.5 kg , Without stand - width: 62.56 cm - depth: 5.38 cm - height: 37.51 cm - weight: 6.4 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 74.3 cm |
Shipping Depth | 31.5 cm |
Shipping Height | 58 cm |
Shipping Weight | 13.5 kg |
