75" LG ULTRA HD 4K TV - 75UJ675V
Key Features
More consistent colour and contrast from any seats
Active HDR expanding your HDR choices
Contrast booster for HDR-like viewing
The science of light control
Upscale the resolution to 4K quality
Surround yourself in rich sound
The Ultra HD innovation is built into the unique IPS 4K panel meaning your entertainment is viewable from any angle without distortion.
Advanced formatting technology enables LG UHD TV to output many recognized High Dynamic Range algorithms, such as HLG and HDR 10. Get the HDR experience from more HDR sources.
Make the ordinary, extraordinary. Advanced picture processing produces an HDR effect for standard dynamic range content. Lift your ordinary entertainment to a new level of color and contrast.
Product Description | LG 75UJ675V 75" LED-backlit LCD TV - 4K | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 75" | Platform | webOS 3.5 | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | HDR Technology | Active HDR | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 4 ports | Connectivity | Wi-Fi, LAN | Technology | IPS | LCD Backlight Technology | Edge-lit LED | Image Aspect Ratio | 16:9 | Digital TV Tuner | DVB-C, DVB-S2, DVB-T2 | Picture Enhancements | Resolution Upscaler, Color Master Engine | Sound Effects | ULTRA Surround | USB | 2 ports | Included Accessories | Remote control, batteries | Voltage | AC 120/230 V (50/60 Hz) | Energy Class | Class A+ | Power Consumption (On mode) | 132 W | Power Consumption Stand by | 0.5 Watt | Energy Consumption per Year | 183 kWh | Dimensions (WxDxH) - without stand | 169.7 cm x 6.5 cm x 98.1 cm | Weight | 41.3 kg |
General | |
HDR Capable | Yes |
TV Tuner Presence | Yes |
Modes | Smart Picture Mode |
Dimensions | Without stand |
Width | 169.7 cm |
Depth | 6.5 cm |
Height | 98.1 cm |
Weight | 41.3 kg |
Display | |
LCD Display Technology | IPS |
Features | Ultra Luminance |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | 600 x 400 mm |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Electronic Programme Guide | Digital EPG |
Media Player | |
Supported Video Formats | HEVC, VP9 |
Supported Audio Formats | MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS, MP2 |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Remote control |
Audio System | |
Digital Audio Format | DTS digital output |
Surround Mode | Yes |
Output Power / Total | 20 Watt |
Features | Built-in DTS decoder, Audio Return Channel (ARC), apt-X technology, Magic Sound Tuning, Hi-Fi Audio, LG Sound Sync |
Network & Internet Multimedia | |
Functionality | WEB browsing, Internet video playback |
Connect & Share | Screen Mirroring, Intel Wireless Display (WiDi), Wi-Fi Miracast |
Supported Consumer Electronics Control (CEC) | Simplink |
Application Store | LG Content Store |
Connections | |
Connector Type | 4 x HDMI input , 2 x USB , LAN , Composite video / component video input , Digital audio output (optical) |
Miscellaneous | |
Included Accessories | Batteries |
Power | |
Power Device | Power supply |
Input Voltage | AC 120/230 V (50/60 Hz) |
Features | Energy save |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 169.7 cm x 6.5 cm x 98.1 cm x 41.3 kg , Panel with stand - 169.7 cm x 36.8 cm x 103.8 cm x 44.3 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 183.9 cm |
Depth (Shipping) | 23.1 cm |
Height (Shipping) | 116.6 cm |
Weight (Shipping) | 55.3 kg |
