LG SJ6 Soundbar
Key Features
High-Resolution Audio
Wireless Subwoofer
ASC (Adaptive Sound Control)
Auto Sound Engine
TV Matching Design
Wi-Fi & Bluetooth Compatible
True to the Original High Resolution
A new standard of sound quality. With advanced audio processing technology delivering sound of 24bit/192kHz quality you have some of the best components available for Hi-Res Audio. Now you can listen to studio standards of sound with lossless playback, experiencing a new level of audio that is true to the original.
Place your Bass Wirelessly
Free your living room from wires. LG’s active wireless subwoofer allows you to enjoy superb sound quality without compromising on design.
Adaptive Audio for what you Watch
Intelligently adaptive audio. LG's unique audio enhancing technology analyses frequency levels as you listen to provide an optimum sound mix based on what you are watching. This advanced process ensures your audio instantly adapts to provide crystal clear dialogue or punchy powerful action whatever you choose to watch.
Optimised Audio
Automatically adjusted audio accuracy. LG Auto Sound Engine optimizes the audio at every volume level keeping the frequencies accurate in the right places. This delivers the correct sound balance no matter what volume your entertainment is playing at.
Picture Perfect Audio Partner
Picture perfect audio partner. Matching 49 inch LG TVs this soundbar mirrors the size and design of your television for the optimum audio visual partnership. Bring symphony to your home entertainment experience with an integrated solution.
Wi-Fi & Bluetooth Compatible, stream anything
LG Soundbar can play any music or run services from your mobile devices without any limits. The Wi-Fi allows for superb audio quality while Bluetooth connectivity provides you with ultimate compatibility.
Chromecast built-in
With built-in Chromecast audio software you can now cast millions of songs, podcasts and stations from your phone directly into the Soundbar. Use your phone as a remote to search, play and pause music and adjust the volume.
Music throughout the home with Chromecast audio
Bulit-in Chromecast Audio allows you to group compatible devices, letting music flow all over the home.
Bluetooth Stand-by, wake up your bar on demand
Sound starts the moment you transfer audio to the Soundbar. The Soundbar remains in sleep mode but turns on and begins playing when the audio is sent via Bluetooth.
Auto Music Play, music that follows you
Sound starts the moment you enter the room With Auto Music Play activated the bar can automatically take over the playback of the audio from a connected device the moment it sense the device is nearby.
Control with your TV Remote
LG Soundbar comes with a remote but you can choose to use your own TV remote as well. (LG, Sony, Philips, Sharp, Panasonic, Vizio, Toshiba and Samsung brand remotes).
Connected to your entertainment
Feel free to connect to the device you wish with HDMI, Optical, Portable In and Bluetooth connectivity.
Product Description | LG SJ6 - sound bar system - for home theatre - wireless | Product Type | Sound bar system - for home theatre | Features | Alarm | System Components | Subwoofer, sound bar | Speaker Type | Active | Nominal Output Power (Total) | 320 Watt | Amplifier | Integrated | Interfaces | Bluetooth, Wi-Fi | Audio Formats | WAV, WMA, AAC, AIFF, MP3, FLAC, LPCM, AAC +, OGG, ALAC | Speaker System Details | 1 x sound bar 120 Watt , 1 x subwoofer 200 Watt | Speaker Details | Sound bar - stereo x 2 - 60 Watt - 2-way - active , Speaker - subwoofer - 200 Watt - active | Built-in Decoders | Dolby Digital, DTS decoder | Sound Effects | Sound Sync, Adaptive Sound Control (ASC), Bass Blast, Cinema |
General | |
Features | Alarm |
Speaker System | |
Audio System Continuous Power (Total) | 320 Watt |
Multiroom | Yes |
Speaker System Details | |
Speakers Included | 1 x sound bar - 120 Watt , 1 x subwoofer - 200 Watt - wireless |
Driver Details | Sound bar: 2 x woofer driver , Sound bar: 2 x tweeter driver |
Driver Details (2nd speaker) | Subwoofer: subwoofer driver - 6" |
Connections | |
Connector Type | HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , SPDIF input (TOS Link) , LAN (RJ-45) |
Miscellaneous | |
Included Accessories | Remote control, cable organizer, audio (optical) cable, wall mounting bracket |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight Details | Sound bar: 95 cm x 8.5 cm x 5.5 cm / 2.8 kg , Subwoofer: 17.1 cm x 25.2 cm x 32 cm / 4.2 kg |
