Enjoy High Fidelity Sound
Each woofer unit is designed with a carbon diaphragm to ensure excellent clarity.
Adaptive Audio for Everything You Watch
AI Sound Pro automatically analyses content and instantly optimises the audio settings for what’s playing. Catch every detail with crystal clear dialogue or more punchy powerful action, depending on the genre.
Powerful bass - easy to install
Feel the beat with the powerful LG Sound Bar SL4Y wireless subwoofer. Pumping out an extra 200 watts, it sounds good and is convenient to install in your room.
Prestigious British Audio, Meridian
Since 1977, Meridian has delivered innovative and elegant high-performance audio solutions. They have pushed boundaries, disrupted norms, and delivered products that have redefined how people enjoy their music and movies, wherever they are.
Meridian’s Leading Technologies
Meridian's rigorous and research-led philosophy has maintained their position on the limits of what's possible in sound. As the Pioneer of High Resolution Audio and the Master of Digital Signal Processing (DSP), Meridian has played an integral role in the development and adoption of pioneering technologies.
Multiple connection options
Easily play music via Bluetooth®, or conveniently connect and play using optical or HDMI cables.
Stream Smart for Quality Sound
Stream music directly from your smartphone to the sound bar via Bluetooth®. Exceptional sound for your music collection is now within reach.
Sync seamlessly with your LG TV
This LG Sound Bar can be simply connected to your LG TV via Bluetooth® or optical cable. Your complete TV audio experience is ready in no time.
Product Description | LG SN4 - sound bar system - for TV - wireless | Product Type | Sound bar system - for TV - 2.1-channel | Media Content Source | USB-host | System Components | Subwoofer, sound bar | Speaker Type | Active | Nominal Output Power (Total) | 300 Watt | Amplifier | Integrated | Interfaces | Bluetooth | Audio Formats | WAV, WMA, AAC, MP3, FLAC, LPCM, AAC +, OGG | Speaker System Details | 1 x sound bar 100 Watt , 1 x subwoofer 200 Watt | Speaker Details | Sound bar - stereo x 2 - 50 Watt - at 1 kHz - 10% THD - 4 Ohm - active , Speaker - subwoofer - 200 Watt - at 80 Hz - 10% THD - 3 Ohm - active | Colour | Black | Built-in Decoders | Dolby Digital, DTS Digital Surround, DTS Virtual:X | Sound Effects | Bass Blast | Power | AC 120/230 V (50/60 Hz) |
General | |
Enclosure Colour | Black |
Speaker System | |
Audio System Continuous Power (Total) | 300 Watt |
Audio Return Channel (ARC) Capability | Yes |
Interfaces | Bluetooth 4.0 |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP) |
Bluetooth Audio Codec | SBC, AAC |
Controls | Power on/off, volume, function key |
App-Controlled | Yes |
Speaker System Details | |
Speakers Included | 1 x sound bar - 100 Watt , 1 x subwoofer - 200 Watt - wireless |
Speaker Details | Sound bar - stereo x 2 - 50 Watt - at 1 kHz CFR - 10% THD - 4 Ohm - active , Speaker - subwoofer - 200 Watt - at 80 Hz CFR - 10% THD - 3 Ohm - active |
Connections | |
Connector Type | Digital audio input (optical) (TOS Link) , HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB (4 PIN USB Type A) |
Miscellaneous | |
Included Accessories | AC power adaptor, digital audio cable (optical), remote control |
Power | |
Power Source | AC power adapter, Integrated power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 56 Watt |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight Details | Sound bar: 89 cm x 8.5 cm x 5.7 cm / 2.1 kg , Subwoofer: 17.1 cm x 26.1 cm x 39 cm / 5.3 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 98.4 cm |
Shipping Depth | 22.7 cm |
Shipping Height | 46.1 cm |
Shipping Weight | 9.4 kg |
