65" LG ULTRA HD 4K TV
Advanced Ultra HD innovation is built into the unique IPS 4K panel, meaning your entertainment is viewable from any angle without distortion. Advanced formatting technology enables LG Ultra HD TV to output many recognized High Dynamic Range algorithms, such as HLG and HDR 10. Get the HDR experience from more HDR sources.
Key Features
More consistent colour and contrast from any seats
Active HDR expanding your HDR choices
Contrast booster for HDR-like viewing
Upscale the resolution to 4K quality
Surround yourself in rich sound
webOS 3.5 simple and fun to use
Product Description | LG 65UJ630V 65" LED-backlit LCD TV - 4K | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 65" | Platform | webOS 3.5 | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | HDR Technology | Active HDR | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN | Technology | IPS | LCD Backlight Technology | Direct-lit LED | Image Aspect Ratio | 16:9 | Digital TV Tuner | DVB-C, DVB-S2, DVB-T2 | Internet Streaming Services | Freeview Play | Picture Enhancements | 4K Upscaling, Resolution Upscaler, Color Master Engine | Speaker System | 2 speakers | Sound Effects | ULTRA Surround | USB | 2 ports | Included Accessories | Universal remote, batteries | Voltage | AC 120/230 V (50/60 Hz) | Energy Class | Class A | Power Consumption (On mode) | 136 W | Power Consumption Stand by | 0.5 Watt | Energy Consumption per Year | 189 kWh | Dimensions (WxDxH) - without stand | 147.1 cm x 8.4 cm x 85.5 cm | Weight | 22.3 kg |
General | |
HDR Capable | Yes |
TV Tuner Presence | Yes |
Modes | Smart Picture Mode |
Design | Slim Design |
Dimensions | Without stand |
Width | 147.1 cm |
Depth | 8.4 cm |
Height | 85.5 cm |
Weight | 22.3 kg |
Display | |
LCD Display Technology | IPS |
Features | Natural Voice Recognition |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | 300 x 300 mm |
TV Tuner | |
Conditional Access | Common Interface (CI) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Digital TV Service | FreeviewPlay |
Video Features | |
Electronic Programme Guide | Digital EPG |
Media Player | |
Supported Video Formats | HEVC, VP9 |
Supported Audio Formats | MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS, MP2 |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Universal remote |
Audio System | |
Digital Audio Format | DTS digital output |
Surround Mode | Yes |
Output Power / Total | 20 Watt |
Features | Built-in DTS decoder, Audio Return Channel (ARC), apt-X technology, Magic Sound Tuning, Hi-Fi Audio, LG Sound Sync |
Speakers | 2 x speaker - 10 Watt |
Network & Internet Multimedia | |
Functionality | WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Connect & Share | Intel Wireless Display (WiDi), Wi-Fi Miracast |
Supported Consumer Electronics Control (CEC) | Simplink |
Application Store | LG Content Store |
DLNA | Yes |
Connections | |
Connector Type | 3 x HDMI input , 2 x USB , LAN , Composite video / component video input , Digital audio output (optical) |
Miscellaneous | |
Included Accessories | Batteries |
Power | |
Power Device | Power supply |
Input Voltage | AC 120/230 V (50/60 Hz) |
Features | Energy save |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 147.1 cm x 8.4 cm x 85.5 cm x 22.3 kg , Panel with stand - 147.1 cm x 25.5 cm x 91.5 cm x 22.5 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 160 cm |
Depth (Shipping) | 19 cm |
Height (Shipping) | 97 cm |
Weight (Shipping) | 29.8 kg |
