55" LG ULTRA HD 4K TV
Key Features
More consistent colour and contrast from any seats
Active HDR, unlike other conventional HDRs
Contrast booster for HDR-like viewing
The science of light control
Upscale the resolution to 4K quality
Powerful sound co-designed by harman/kardon®
Product Description | LG 55UJ750V 55" LED-backlit LCD TV - 4K | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 55" | Platform | webOS 3.5 | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | HDR Technology | Active HDR with Dolby Vision | Video Interface | HDMI | HDMI Ports Qty | 4 ports | Connectivity | Wi-Fi, LAN | Technology | IPS | LCD Backlight Technology | Edge-lit LED local dimming | Image Aspect Ratio | 16:9 | Digital TV Tuner | DVB-C, DVB-S2, DVB-T2 | Internet Streaming Services | Freeview Play | Picture Enhancements | 4K Upscaling, Resolution Upscaler, Color Master Engine, Active Depth Enhancer | Sound Effects | ULTRA Surround | USB | 2 ports | Included Accessories | Universal remote, batteries | Voltage | AC 120/230 V (50/60 Hz) | Energy Class | Class A+ | Power Consumption (On mode) | 75 W | Power Consumption Stand by | 0.5 Watt | Energy Consumption per Year | 104 kWh | Dimensions (WxDxH) - without stand | 123.6 cm x 6.2 cm x 71.8 cm | Weight | 15.3 kg |
General | |
HDR Capable | Yes |
TV Tuner Presence | Yes |
Modes | Smart Picture Mode |
Dimensions | Without stand |
Width | 123.6 cm |
Depth | 6.2 cm |
Height | 71.8 cm |
Weight | 15.3 kg |
Display | |
LCD Display Technology | IPS |
LCD Backlight Technology | Edge-lit LED - local dimming |
Features | Natural Voice Recognition, Ultra Luminance |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | 300 x 300 mm |
TV Tuner | |
Conditional Access | Common Interface (CI) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Electronic Programme Guide | Digital EPG |
Media Player | |
Supported Video Formats | HEVC, VP9 |
Supported Audio Formats | MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS, MP2 |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Universal remote |
Features | Magic remote |
Audio System | |
Digital Audio Format | Dolby Digital output, DTS digital output |
Surround Mode | Yes |
Output Power / Total | 20 Watt |
Features | Built-in DTS decoder, Audio Return Channel (ARC), Magic Sound Tuning, Hi-Fi Audio, LG Sound Sync |
Network & Internet Multimedia | |
Functionality | Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Connect & Share | Intel Wireless Display (WiDi), Wi-Fi Miracast |
Supported Consumer Electronics Control (CEC) | Simplink |
Application Store | LG Content Store |
Connections | |
Connector Type | 4 x HDMI , 2 x USB , Composite video / component video input , LAN , Digital audio output (optical) , Audio line-out / headphones , Audio line-in |
Miscellaneous | |
Included Accessories | Batteries |
Power | |
Power Device | Power supply |
Input Voltage | AC 120/230 V (50/60 Hz) |
Features | Energy save |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 123.6 cm x 6.2 cm x 71.8 cm x 15.3 kg , Panel with stand - 123.6 cm x 24.8 cm x 77.4 cm x 16.7 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 136 cm |
Depth (Shipping) | 17.5 cm |
Height (Shipping) | 86 cm |
Weight (Shipping) | 21.9 kg |
