Logitech B100 Optical Mouse for Business White
£10.00
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • 800 dpi optical precision
  • Zero setup
  • Comfort in hand
  • Smooth operator
  • Recommended Use: Office
  • Type: Mouse
  • Wired / Wireless: Wired
  • Colour: White, Light
  • Compatibility: PC, Unix, Mac
Product codes
chevron icon
chevron icon
A comfortable plug-and-play mouse with built-in quality and optical precision!
You'll enjoy smooth, precise cursor control that lets you edit documents and navigate the Web more efficiently.
It works right out of the box - you just plug it into your USB port and you're ready for business.
Left-handed or right, you can work comfortably all day long with this ambidextrous mouse.
You're in control with smooth, responsive optical tracking that moves the cursor just where you want it.
chevron icon
Product Description Logitech B100 - mouse - USB - white
Device Type Mouse
Connectivity Technology Wired - USB
Colour White
Orientation Right and left-handed
Dimensions (WxDxH) 6.17 cm x 11.3 cm x 3.84 cm
Weight 85 g
Movement Detection Technology Optical
Buttons Qty 3
Movement Resolution 800 dpi
Features Scrolling wheel
Cables Included 1 x USB cable - integrated - 1.8 m
OS Required Linux 2.4 or later, Microsoft Windows 7, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification Compatible with Windows 7
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£10.00
