Logitech Desktop MK120 - Keyboard & Mouse - USB
£16.04
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • With a sleek, comfortable keyboard and high-definition optical mouse, this durable duo brings comfort, style and simplicity together.
  • Comfortable, quiet typing
  • Spill-resistant design
  • High-definition optical tracking
  • Thin profile
  • Durable keys
  • Plug-and-play USB connections
  • Easy-to-read keys
  • Sturdy, adjustable tilt legs
  • Logitech reliability
  • Curved space bar
  • Feel-good typing
  • Rugged good looks
  • Smooth ride
  • Recommended Use: Leisure
  • Type: Keyboard
  • Wired / Wireless: Wired
  • Colour: Black
  • Compatibility: PC
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £19.53
Save £1.50
Logitech Desktop MK120 is a durable duo that brings comfort, style and simplicity together. You'll be comfortable with the keyboard thanks to the low-profile, whisper-quiet keys and standard layout with full-size F-keys and number pad. With its thin profile, spill-resistant design, durable keys that can withstand up to 10 million keystrokes and sturdy, adjustable tilt legs, this sleek keyboard not only looks and feels good - it's built to last. Plus, it's got easy-to-read keys. The high-definition optical mouse puts comfort and control in your hands with smooth, accurate tracking and a comfortable, ambidextrous shape. And setup is simple - you just plug your keyboard and mouse into USB ports and start using them right out of the box.
You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound and standard layout with full-size F-keys and number pad.
Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills.
You'll enjoy responsive and smooth cursor control with the high-definition optical tracking (1000 dpi).
Thin profile
The keyboard has a thin profile that adds a sleek look to your desk while keeping your hands in a more comfortable, neutral position.
Durable keys
The keys can last up to 10 million keystrokes so you can keep typing long after many keyboards have called it quits.
Setup is simple--you just plug your keyboard and mouse into USB ports on your desktop, laptop or netbook computer and start using them right out of the box.
Easy-to-read keys
The bold, bright white characters make the keys easier to read--perfect for those with less-than-perfect vision. They're less likely to wear off, too.
You can extend the sturdy folding legs to increase the keyboard tilt by 8 degrees to address your personal ergonomic needs.
Curved space bar
It keeps your hands in a more natural position so you can type in greater comfort.
You get the high quality and reliability that's made Logitech the global leader for keyboards and mice at a price you can afford--plus a 3-year warranty.
Product Description Logitech Desktop MK120 - keyboard and mouse set - English
Device Type Keyboard and mouse set
Interface USB
Input Device Keyboard
Connectivity Technology Wired
Localization and Layout English
Features Spillproof, tilt legs
Pointing Device Mouse - optical
Features Scrolling wheel, 1000 dpi resolution
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Logitech Desktop MK120...
£16.04
