G602 redefines the laws of wireless gaming. From the pinpoint accuracy of exclusive Delta Zero sensor technology to high durability primary switches to 11 programmable controls, G602 offers true gaming performance. Count on G602 to dominate boss after boss.
Product Description | Logitech Gaming Mouse G602 - mouse - 2.4 GHz | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Orientation | Right-handed | Movement Detection Technology | Laser | Buttons Qty | 11 | Movement Resolution | 2500 dpi | Performance | 500 reports per second, 20 G maximum acceleration, realtime sensitivity switching 250 - 2500 dpi, 80 inches per second | Features | Programmable buttons, scrolling wheel, sensitivity adjustment, battery indicator, Delta Zero sensor technology | Cables Included | USB extension cable - external | Battery | 2 x AA type | OS Required | Apple MacOS X 10.6.8 or later, Microsoft Windows Vista / 7 / 8 | Manufacturer Warranty | 3-year warranty |
General | |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Max Operating Distance | Up to 3 m |
Buttons Qty | 11 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Battery | |
Type | AA type |
Installed Qty | 2 |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
