Logitech Keyboard K120 - USB
£11.11
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Comfortable, quiet typing
  • Spill-resistant design
  • Thin profile
  • Durable keys
  • Sturdy, adjustable tilt legs
  • Plug-and-play USB connection
  • Recommended Use: Leisure, Office
  • Type: Keyboard
  • Wired / Wireless: Wired
  • Colour: Black, Dark
  • Compatibility: PC
Product codes
chevron icon
chevron icon
Your hands will enjoy the low-profile, whisper-quiet keys and standard layout with full-size F-keys and number pad. The slim keyboard isn't just sleek-it's tough with a spill-resistant design, sturdy tilt legs and durable keys. You simply plug it into a USB port on your desktop, laptop or netbook computer and start using it right away.
With low-profile keys, a standard layout and a sleek yet sturdy design, this USB keyboard gives you a better typing experience that's built to last.
You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound and standard layout with full-size F-keys and number pad.
Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills
Thin profile
The keyboard has a thin profile that adds a sleek look to your desk while keeping your hands in a more comfortable, neutral position.
Durable keys
The keys can last up to 10 million keystrokes so you can keep typing long after many keyboards have called it quits
Setup is simple--you just plug it into a USB port on your desktop, laptop or netbook computer and start using it right out of the box.
Easy-to-read keys
The bold, bright white characters make the keys easier to read--perfect for those with less-than-perfect vision. They're less likely to wear off, too.
Curved space bar
It keeps your hands in a more natural position so you can type in greater comfort.
Logitech reliability
You get the high quality and reliability that's made Logitech the global leader for keyboards and mice at a price you can afford--plus a 3-year warranty.
chevron icon
Product Description Logitech K120 - keyboard - UK Input Device
Device Type Keyboard
Interface USB
Connectivity Technology Wired
Localization and Layout UK
Features Spillproof
Dimensions (WxDxH) 45 cm x 15.5 cm x 2.4 cm
Weight 0.55 kg
Microsoft Certification Compatible with Windows 7
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£11.11
