Logitech Mouse M100 gives you just the basics for comfortable, reliable control of your computer. There is no software to install. And since it is corded, you can just plug the cable into a USB port and use it right away. The full-size, ambidextrous shape means your hand will rest comfortably, while high-definition optical tracking (1000 dpi) means you will get responsive, smooth cursor control for precise tracking and easy text selection.
Product Description | Logitech M100 - mouse - USB - white | Device Type | Mouse | Connectivity Technology | Wired - USB | Colour | White | Orientation | Right and left-handed | Dimensions (WxDxH) | 6.1 cm x 11.2 cm x 3.9 cm | Weight | 64 g | Localisation | Western Europe | Movement Detection Technology | Optical | Buttons Qty | 3 | Movement Resolution | 1000 dpi | Features | Scrolling wheel | OS Required | Apple MacOS X 10.4 or later, Linux Kernel 2.6.x or later, Microsoft Windows Vista / XP / 7 | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 6.1 cm |
Depth | 11.2 cm |
Height | 3.9 cm |
Weight | 64 g |
Colour | White |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Buttons Qty | 3 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Software / System Requirements | |
Additional Requirements | USB port |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
