We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Mini Mouse is so small it'll easily fit in your purse, handbag or pant pocket for extra-portability.
Say good-bye to cords and enjoy wireless freedom, so it's easy to use your mouse on the couch with your laptop - or even when you're hooking your laptop up to your TV.
Product Description | Logitech M187 - mouse - 2.4 GHz - black | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Black | Dimensions (WxDxH) | 5 cm x 8 cm x 2.5 cm | Weight | 51 g | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Features | Scrolling wheel, Nano wireless receiver | Battery | 1 x AAA type | OS Required | Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 5 cm |
Depth | 8 cm |
Height | 2.5 cm |
Weight | 51 g |
Colour | Black |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Max Operating Distance | Up to 10 m |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Battery | |
Type | AAA type |
Installed Qty | 1 |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
