A wireless mouse that delivers a better mix of precision and comfort--with designed-for-Web scrolling and a feel-good, contoured design.
Micro-precise scrolling
Designed for how you use the Web, our newest micro-precise scrolling makes reading your Facebook® or scrolling through Google® searches easier. Plus, tilting the wheel moves you backward or forward on the Web
Hyper-fast scrolling
Your spreadsheets and documents are getting longer. Your digital photo and music libraries are bursting at the seams. And you're glued to long Web pages that have you scrolling and scrolling and .... To get through it all, you're doing a whole lot of scrolling. We're talking 26 feet of it in your average eight-hour day, according to a Logitech study.
That's where hyper-fast scrolling comes in.
When you need to do some long-distance scrolling, hyper-fast scrolling unleashes the speed demon inside. What's going on under the hood? The ratchet-scrolling mechanism you're used to retracts so the wheel can spin with virtually no friction.
Seven seconds. That's how long some of our scroll wheels spin freely--speeding you through hundreds of pages or thousands of rows.
And, oh yeah, it's got precision handling too. With normal click-to-click scrolling, you can navigate your lists, slides, and images with the line-by-line control you need.
Comfortable contoured design
Based on the best-selling shape in the world, the contoured shape with textured rubber grips keeps your hand happy--even after long hours.
Up to 18-month battery life
The long battery life virtually eliminates the hassle of changing batteries. Smart sleep mode saves power, while an indicator light eliminates surprises
Logitech Unifying Nano-receiver
The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless device--without the hassle of multiple USB receivers.
Logitech Advanced 2.4 GHz wireless
You get the reliability of a cord with wireless convenience and freedom--fast data transmission and virtually no delays or dropouts.
Logitech Advanced Optical Tracking
From surfing the Web to navigating your Facebook with precision clicking, pointing and dragging, everything you do on your laptop is just easier thanks to our advanced tracking technology. And you don't need a mouse pad either.
Logitech reliability
You get the high quality and reliability that have made Logitech the global leader for mice at a price you can afford--plus a three-year limited hardware warranty
Perfect for laptops and netbooks
Your mouse works with Windows®, Mac® and Linux®. No matter what type of computer you own today--or buy tomorrow--you can depend on your mouse to work like you expect.
Product Description | Logitech M325 - Color Collection Limited Edition - mouse - 2.4 GHz - light grey | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Light grey | Dimensions (WxDxH) | 5.7 cm x 9.8 cm x 3.9 cm | Weight | 88 g | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Buttons Qty | 3 | Features | Tilt Wheel technology, on/off power switch, Logitech Unifying receiver | Battery | 1 x AA type | OS Required | Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5.x or later | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 5.7 cm |
Depth | 9.8 cm |
Height | 3.9 cm |
Weight | 88 g |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Buttons Qty | 3 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Battery | |
Type | AA type |
Installed Qty | 1 |
Run Time (Up To) | 18 months |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
