Enjoy the convenience of wireless streaming and never worry about battery life because this 2.1 speaker system is always plugged in. Its 80 Watts Peak/40 Watts RMS power delivers bold sound. Easily access the Bluetooth pairing button from the wired control pod. Adjust the bass level with the dedicated control knob on the back of the subwoofer. For a wired connection use the 3.5mm or RCA inputs.
Product Description | Logitech Z337 - speaker system - wireless | Product Type | Speaker system - 2.1-channel | System Components | 2 speakers, subwoofer | Speaker Type | Active | Nominal Output Power (Total) | 40 Watt | Audio System Peak Power (Total) | 80 Watt | Amplifier | Integrated | Interfaces | Bluetooth | Speaker System Details | 1 x subwoofer 24 Watt , 2 x satellite speaker 8 Watt | Manufacturer Warranty | 2-year warranty |
General | |
Speaker System | |
Audio System Continuous Power (Total) | 40 Watt |
Interfaces | Bluetooth 4.1 |
Transmission Range | 15 m |
Controls | Power on/off, volume, bass |
Headphone Output Jack | Yes |
Speaker System Details | |
Speakers Included | 1 x subwoofer - 24 Watt - wired , 2 x satellite speaker - 8 Watt - wired |
Connections | |
Connector Type | Audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) , Headphones (mini-phone stereo 3.5 mm) |
Miscellaneous | |
Included Accessories | Audio cable, wired remote control |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight Details | Satellite speaker: 10.8 cm x 9 cm x 19.28 cm / 640 g , Subwoofer: 23.2 cm x 15.7 cm x 23 cm / 2.4 kg , Control unit: 5.4 cm x 5.5 cm x 5.5 cm / 72 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
