ITEM | QTY | PRICE |
Dell P2722HE 27" 1920x1080 8ms H...
4 | £918.32 |
Dell OptiPlex 7010 SFF Intel Core i5-...
4 | £2,471.56 |
BT Big Button 200
4 | £111.96 |
Play in comfort with this adjustable, ergonomic head strap that fits most head sizes with the quick turn of a dial. This Elite Strap upgrades your fit by taking pressure off your face for increased comfort and weight distribution. The soft, flexible silicone support cradles the back of your head, reducing fatigue. This genuine Meta Quest accessory easily installs on your Meta Quest 3 for a perfect and secure fit every time you play, create and explore in VR.
Ready for action
This compact, lightweight strap reduces facial pressure and evenly distributes weight for a more comfortable fit. It also has improved durability, building on the learnings from our earlier generations of Elite Strap.
Adjusts in seconds
A twist of the adjustment dial gives you a snug, precise fit around your head, so you can move confidently whether you're battling it out or getting your sweat on.
Longer immersion
A soft, flexible silicone support cradles the back of your head for the most comfortable and balanced fit for any experience.
Perfect alignment
This flexible top strap adjusts to keep your headset at a comfortable position over your eyes and further disperses weight.
Seamless compatibility
Works with the Meta Quest 3 Charging Dock for effortless headset and controller charging. Also fits in the Meta Quest 3 Carrying Case without having to be removed.
Genuine Meta Quest accessory
Built to work seamlessly with Meta Quest 3 and backed by a one year warranty, this official accessory has been tested for quality and durability – ensuring you get the best look, feel, compatibility and performance.
Product Description | Meta Quest 3 - head strap for virtual reality headset | Product Type | Head strap | Intended For | Virtual reality headset | Package Content | Head strap | Product Material | Plastic, fabric, silicone | Dimensions (WxDxH) | 16.45 cm x 24.02 cm x 10.15 cm | Weight | 183 g | Colour | White | Designed For | Meta Quest 3 |
General | |
Width | 16.45 cm |
Depth | 24.02 cm |
Height | 10.15 cm |
Weight | 183 g |
Colour | White |
Compatibility Information | |
