Maximum comfort, customized for you
With its contoured design, customizable features that easily adjust to your needs, and a specially designed, right-handed mouse, Sculpt Comfort Desktop transforms the way you use a keyboard and mouse. It helps you keep your wrists in a neutral position, while providing functionality and shortcuts that improve typing efficiency.
Modern modular design
The sleek design and comfort curve layout keep keys within easy reach, while straightening wrists with ergonomic palm support that protects against inflammation and repetitive stress injuries. The split spacebar offers new backspace functionality to help you make the most of your keystrokes. Tight workspace? Sculpt Comfort Desktop can be easily customized to save space, and offer a more compact look, by detaching the palm rest.
Windows 8 integration
Sculpt Comfort Desktop perfectly integrates with Windows 8. The keyboard hotkeys provide shortcuts to the most commonly used keyboard functions. The Windows Touch tab, a touch-sensitive strip located on the side of the mouse, enables you to take advantage of swiping functionality as you navigate the Start screen.
Product Description | Microsoft Sculpt Comfort Desktop - keyboard and mouse set - UK | Device Type | Keyboard and mouse set - ergonomic | Interface | 2.4 GHz | Wireless Receiver | USB wireless receiver | Connectivity Technology | Wireless | Localization and Layout | UK | Keys Qty | 105 | Hot Keys Function | Calculator, volume, search, mute, play/pause | Features | Removable palm rest, battery LED indicator, split spacebar with backspace functionality | Pointing Device | Mouse - optical | Buttons Qty | 3 | Features | Scrolling wheel (4-way), BlueTrack Technology, right-handed, Windows touch tab | Manufacturer Warranty | 3-year warranty |
General | |
Max Operating Distance | Up to 10 m |
Dimensions (WxDxH) / Weight | Keyboard: 45.3 cm x 21.3 cm x 3.3 cm / 807 g , Mouse: 6.85 cm x 11.1 cm x 3.65 cm / 135 g |
Input Device | |
Type | Wireless |
Keyboard Name | Microsoft Sculpt Comfort Keyboard |
Keys Qty | 105 |
Pointing Device | |
Type | Mouse |
Pointing Device Name | Microsoft Sculpt Comfort Mouse |
Buttons Qty | 3 |
Movement Detection Technology | Optical |
Pointing Device Features | Scrolling wheel (4-way), BlueTrack Technology, right-handed, Windows touch tab |
Miscellaneous | |
Compliant Standards | UL, VCCI, BSMI, ISO 9001, GOST, cUL, ISO 14001, WHQL, CB, RSS-210, IC, MIC, FCC, NTRA, AES-128, KCC, WEEE, ACA, ANATEL, TELEC, URSEC, UkrSEPRO |
Software & System Requirements | |
OS Required | Microsoft Windows 7, Apple MacOS X 10.4 or later, Windows 8, Windows RT |
Battery | |
Installed Qty | 2 |
Required Qty | 2 |
Technology | Alkaline |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 80% (non-condensing) |
