Surface Book transforms into three different configurations, adapting to the way that you work and the places where you create. Surface Book is a powerful laptop with a full sized, backlit keyboard for fast and natural typing.
The 13.5" PixelSense display detaches easily from the keyboard to become a thin, light tablet that works perfectly with OneNote and Surface Pen. Turn the screen around and reattach it to use Surface Book like a creative canvas. By reconnecting it to the keyboard, you unlock its full creative power in a pen first mode.
Use the multi-touch PixelSense screen and Surface Pen to create with all the desktop software you already use, like Adobe Photoshop and Illustrator. Surface Book is the creative professional's laptop, designed to power through professional grade photo and video editing.
Comes with Surface Dock (PF3-00012)
Product Description | Microsoft Surface Book - 13.5" - Intel Core i7 - 6600U - 8 GB RAM - 256 GB SSD - UK - with Surface Dock | Product Type | Tablet - with keyboard dock | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i7 (6th Gen) - 6600U / 2.6 GHz, up to 3.4 GHz / 4 MB Cache | Memory | 8 GB LPDDR3 | Storage | 256 GB SSD | Display | 13.5" touchscreen 3000 x 2000 | Graphics | NVIDIA GeForce 940M | Video Memory | 1 GB GDDR5 SDRAM | Input Device | Detachable keyboard, Surface Pen | Keyboard | UK | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac | Battery | Up to 12 hours | Features | Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor | Dockable | Yes | Security | Trusted Platform Module (TPM) Security Chip | Colour | Silver | Dimensions (WxDxH) | 31.23 cm x 23.21 cm x 2.28 cm | Weight | 1.576 kg | Localisation | Region: United Kingdom, Ireland | Environmental Standards | - EPEAT Climate+ | Specific Absorption Rate (SAR) | 0.72 W/kg (body) | Manufacturer Warranty | Limited warranty - 1 year | Bundled with | Surface Dock |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6600U / 2.6 GHz |
Max Turbo Speed | 3.4 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Memory | |
RAM | 8 GB |
Technology | LPDDR3 SDRAM |
Storage | |
Main Storage | 256 GB SSD |
Display | |
Type | 13.5" |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 3000 x 2000 |
Widescreen | Yes |
Image Aspect Ratio | 3:2 |
Features | PixelSense |
Audio & Video | |
Graphics Processor | NVIDIA GeForce 940M |
Camera | Yes - 1080p |
Resolution | 8 Megapixel (rear), 5 Megapixel (front) |
Camera Features | Autofocus, Windows Hello |
Sound | Stereo speakers, two microphones |
Input | |
Type | Detachable keyboard, Surface Pen |
Keyboard Layout | UK |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac |
Battery | |
Run Time | Up to 12 hours |
Connections & Expansion | |
Interfaces Details | 2 x USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , 2 x SurfaceConnect |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Software | |
Software Included | Microsoft Office (30 days trial) |
Miscellaneous | |
Colour | Silver |
Case Material | Magnesium alloy |
Integrated Options | Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor |
Dockable | Yes |
Included Accessories | Keyboard |
SAR Value | 0.72 W/kg (body) |
Localization | Region: United Kingdom, Ireland |
Dimensions & Weight | |
Weight | 1.576 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
