Style and speed. Think in color with Surface Laptop 2. Sleek and light, with improved speed and performance, slip it in your bag and make every day more productive.
Product Description | Microsoft Surface Laptop 2 - 13.5" - Intel Core i7 - 8650U - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Windows 10 Home | Processor | Intel Core i7 (8th Gen) - 8650U / 1.9 GHz, up to 4.2 GHz / 8 MB Cache | Memory | 8 GB LPDDR3 | Storage | 256 GB SSD | Display | 13.5" touchscreen 2256 x 1504 - 201 ppi | Graphics | Intel UHD Graphics 620 | Input Device | Trackpad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | Up to 14.5 hours | Features | Ambient light sensor | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Platinum | Dimensions (WxDxH) | 30.81 cm x 22.327 cm x 1.448 cm | Weight | 1.283 kg | Specific Absorption Rate (SAR) | 0.18 W/kg (body) | Manufacturer Warranty | Limited warranty - 1 year |
General | |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8650U / 1.9 GHz |
Max Turbo Speed | 4.2 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Features | Intel Smart Cache |
Memory | |
RAM | 8 GB |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD |
Display | |
Type | 13.5" |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 2256 x 1504 |
Widescreen | Yes |
Pixel Density (ppi) | 201 |
Image Aspect Ratio | 3:2 |
Colour Gamut | 100% sRGB |
Features | Corning Gorilla glass 3, PixelSense, fingerprint-resistant oleophobic coating |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Camera | Yes - 720p |
Camera Features | Windows Hello |
Sound | Stereo speakers, stereo microphone |
Compliant Standards | Dolby Audio Premium |
Input | |
Type | Keyboard, trackpad |
Keyboard Layout | UK |
Features | Soft-touch surface, multi-gesture trackpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Battery | |
Run Time | Up to 14.5 hours |
AC Adapter | |
Output | 44 Watt |
Connections & Expansion | |
Interfaces Details | USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , SurfaceConnect (magnetic power and docking) |
Software | |
Software Included | Microsoft 365 (30 days trial) |
Miscellaneous | |
Colour | Platinum |
Case Material | Aluminum |
Integrated Options | Ambient light sensor |
Dockable | Yes |
Included Accessories | Power adapter |
SAR Value | 0.18 W/kg (body) |
Dimensions & Weight | |
Weight | 1.283 kg |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
