Netatmo personal weather station
Master your own climate measurements on your smartphone.
Discover your external environment
The Weather Station's Outdoor Module gives you real-time weather information that matters: gathered right at your doorstep.
- Outdoor temperature
- Outdoor relative humidity
- Outdoor air quality
- Barometric pressure
- Weather forecast
Discover your home environment
The Weather Station's Indoor Module measures your indoor comfort by providing vital information, alerting you when you need to air out your home to bring down its pollution levels.
- Temperature
- Humidity
- Air quality
- Ventilation warning
- Sound meter
A healthier home
We spend 80% of our time indoors, and yet indoor air is often more polluted than outdoor air. The Netatmo Weather Station measures indoor pollution levels through a CO2 sensor, sending you alerts so you can air out your home when necessary and live in a healthier environment.
Analyze past readings, observe the present and forecast the future.
The App allows you to view your data in graph form for real-time tracking of your environment. Observe the cycles and forecast variations around you.
Just ask for your ultra-local weather measurements!
Amazon alexa:
Just say « Alexa, ask Netatmo what’s the temperature outside" to decide if you should bike or drive to work.
Say « Alexa, ask Netatmo how much it has been raining today " to know if you need to water your garden.
Streamlined design, instinctively ergonomic
An elegant design made to last. One-piece aluminum body.
Elegant design - The Weather Station's elegant design fits easily and discreetly into any home.
CO2 Sensor - Just press the top of the Weather Station's Indoor Module to view indoor CO2 levels via its light indicator.
Solid and resistant - The Outdoor Module's solid one-piece aluminum body is completely weatherproof.
Product Description | Netatmo NWS01-EU - weather station | Product Type | Weather station - indoor, outdoor | External Sensors Included | Yes | Measuring Functions | Temperature, humidity, barometric pressure, CO2 | Weather Forecast | 7 days | Thermometer Scale | Celsius, Fahrenheit | Included Accessories | USB cable, 2 AAA batteries, USB power adapter | Networking | Wireless - 802.11b/g/n - 2.4 Ghz | Supported Host Device Platform | iOS, Android |
General | |
Features | Air quality indicator, indoor sound metre |
Weather Measuring | |
Parameter | Indoor temperature: 0 °C to 50 °C - accuracy: +/- 0.3° , Outdoor temperature: -40 °C to 65 °C - accuracy: +/- 0.3° , Humidity: 0 % to 100 % - accuracy: +/- 3% , Barometric pressure: 195 mmHg to 870 mmHg - accuracy: +/- 0.7 mmHg , Indoor CO2 level: 0 ppm to 5000 ppm - accuracy: +/- 5% , Indoor sound level: 35 dB to 110 dB |
Networking | |
Connectivity Technology | Wireless |
Wireless Protocol | 802.11b/g/n |
Frequency Band | 2.4 Ghz |
Max Range Open Space | 100 m |
Miscellaneous | |
Dimensions & Weight | |
Dimensions & Weight Details | Indoor module: 4.5 cm x 4.5 cm x 15.5 cm , Outdoor module: 4.5 cm x 4.5 cm x 10.5 cm |
