Compatible with M4300-96X models (XSM4396K0, XSM4396K1). The NETGEAR M4300-96X is a 2RU modular switch that comes either empty or pre-populated with 48 SFP+ ports and supporting up to 96-port 10GBASE-T copper (RJ-45) with first 48 ports capable of PoE+, 96-port 10GBASE-X fiber (SFP+), 24-port 40GBASE-X fiber (QSFP+), or a combination. The M4300 family provides world-class services for server and storage interconnect, mid-enterprise edge and SMB core. SDVoE-Ready, M4300 switches streamline AV-over-IP deployments with Zero Touch multicast. Layer 3 feature set includes static, policy-based and dynamic routing as standard.
Product Description | NETGEAR APM408P - expansion module - 1/2.5/5/10GBase-T (PoE+) x 8 | Device Type | Expansion module | Form Factor | Plug-in module | Ports | 1/2.5/5/10GBase-T (PoE+) x 8 | Weight | 430 g | Localisation | Worldwide | Cabling Type | Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T | Data Link Protocol | 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE | Data Transfer Rate | 10 Gbps | Compliant Standards | IEEE 802.3af, IEEE 802.3at |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet |
Features | PoE+ |
Expansion / Connectivity | |
Interfaces | 8 x 1/2.5/5/10GBase-T (PoE+) - RJ-45 - female |
Dimensions & Weight | |
Weight | 430 g |
