The NETGEAR M4300 Switch Series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB aggregation deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series. Non-stop forwarding virtual chassis architectures provide advanced High Availability (HA) with hitless failover, that is, distributed link aggregation allows for load balancing and virtually zero downtime. License-free L3 feature set includes static routing, policy-based routing, RIP, VRRP, OSpiv as well as Multicast PIM routing. The NETGEAR M4300 Switch Series is ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
M4300-8X8F comes with 8 ports 10GBASE-T and 8 ports 10GBASE-X SFP+ in a half-width form factor. All 16 ports are independent and 1G backward compatible for progressive transition to 10G speeds. Ideal for server and storage aggregation: two half-width M4300 switches can be installed in a single rack space. M4300-8X8F is line-rate with 320Gbps fabric for SMB core applications as well as spine and leaf stacking architectures.
Product Description | NETGEAR M4300-8X8F - switch - 16 ports - Managed - rack-mountable | Device Type | Switch - 16 ports - L3 - Managed - stackable | Enclosure Type | Front to back airflow rack-mountable 1U | Subtype | 10 Gigabit Ethernet | Ports | 8 x 10/100/1000/10000 + 8 x 10 Gigabit SFP+ | Performance | Switching capacity: 320 Gbps | Routing Protocol | OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2 | Remote Management Protocol | SNMP, Telnet, HTTPS, SSH, CLI | Features | ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM | Compliant Standards | IEEE 802.3ad (LACP), IEEE 802.3az | Power | AC 120/230 V | Localisation | Europe, Americas | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Max Units In A Stack | 8 |
Authentication Method | RADIUS, TACACS+ |
Expansion / Connectivity | |
Interfaces | 8 x 10GBase-T RJ-45 , 8 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A |
Power | |
Power Device | Internal power supply |
Power Provided | 250 Watt |
Voltage Required | AC 120/230 V |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
