NetGear PAV12V AC/DC Power Adapter for Wireless-AC Access Points
Product Description | NETGEAR - power adapter | Device Type | Power adapter - external | Localisation | United Kingdom | Output Voltage | 12 V | Manufacturer Warranty | Limited lifetime warranty |
General | |
Power Device | |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Customer return - item has been used and shows signs of use
Ref: BYLB 046110 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£1.66
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
