NETGEAR ProSAFE M4300-24X Switch 24 Ports Managed Rack-Mountable
£3,745.33
Delivery:
Standard: 1-3 working days
Key features
  • Cost effective 1G access layer in campus LAN networks, and high performance 10G distribution layer for midsize organizations networks
  • Advanced Layer 2, Layer 3 and Layer 4 feature set - no license required - including Policy Based Routing, RIP, VRRP, OSPF and PIM
  • Innovative mixed "Spine and Leaf", 1G and 10G stacking with nonstop forwarding and hitless failover redundancy
  • Up to 384 (Gigabit) ports, or 384 (10 Gigabit) ports, or a combination of both in a single logical switch
  • PoE+ (30 watts per port) with hot swap, redundant power supplies and full provisioning
  • Mixed Stack of 1G and 10G models provides 16K MAC, 2K ARP/NDP, 4K VLANs and 512 routes
  • Type: 10 Gigabit Ethernet
  • Ports: 24, 16-28
  • Data Transfer Rate: [N/A]
  • Managed: Yes
  • POE: No
Product codes
chevron icon
chevron icon
The NETGEAR M4300 Stackable Switch Series delivers L2/L3/L4 and IPv4/IPv6 cost-effective services for mid-enterprise edge with full PoE+ and SMB core deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series, enabling spine and leaf line-rate stacking topologies. Non-stop forwarding (NSF) virtual chassis architectures provide advanced High Availability (HA) with hitless failover across the stack. Dual redundant, modular power supplies equipping full width models contribute to business continuity management. Layer 3 feature set includes static, dynamic and policy-based routing - as standard. Perfect for wireless access, unified communications and IP video, the NETGEAR M4300 Switch Series is also ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
chevron icon
Product Description NETGEAR M4300-24X - switch - 24 ports - Managed - rack-mountable
Device Type Switch - 24 ports - L3 - Managed - stackable
Enclosure Type Front to back airflow rack-mountable 1U
Subtype 10 Gigabit Ethernet
Ports 24 x 10 Gigabit Ethernet + 4 x shared 10 Gigabit SFP+
Performance Switching capacity: 480 Gbps , Throughput: 357 Mpps , 10 Gbps fibre latency (64-byte packets): 1.827 µs , 10 Gbps fibre latency (512-byte packets): 1.919 µs , 10 Gbps fibre latency (1024-byte packets): 1.971 µs , 10 Gbps fibre latency (1518-byte packets): 1.905 µs , 10 Gbps copper latency (64-byte packets): 2.728 µs , 10 Gbps copper latency (512-byte packets): 2.85 µs , 10 Gbps copper latency (1024-byte packets): 2.904 µs , 10 Gbps copper latency (1518-byte packets): 2.841 µs , 1 Gbps fibre latency (64-byte packets): 2.289 µs , 1 Gbps fibre latency (512-byte packets): 2.393 µs , 1 Gbps fibre latency (1024-byte packets): 2.423 µs , 1 Gbps fibre latency (1518-byte packets): 2.379 µs , 1 Gbps copper latency (64-byte packets): 2.707 µs , 1 Gbps copper latency (512-byte packets): 2.821 µs , 1 Gbps copper latency (1024-byte packets): 2.866 µs , 1 Gbps copper latency (1518-byte packets): 2.826 µs
Capacity Virtual interfaces (VLANs): 4093 , IGMP groups: 4000 , LAG groups: 128 , IPv4 routes (static): 64 , IPv6 routes (static): 64 , RIP routes: 512 , IP router interfaces: 128 , OSPF IPv4 routes: 4096 , OSPF IPv6 routes: 256
MAC Address Table Size 16K entries
Jumbo Frame Support 9KB
Routing Protocol OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol SNMP 1, SNMP 2, Telnet, SNMP 3, HTTPS, SSH, CLI
Features ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM
Compliant Standards IEEE 802.3ad (LACP), IEEE 802.3az
Power AC 120/230 V
Dimensions (WxDxH) 21.2 cm x 34.5 cm x 4.4 cm
Weight 4.14 kg
Localisation Europe, Americas
Manufacturer Warranty NETGEAR lifetime warranty
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£3,745.33
