The ReadyNAS 210 is powered by a quad core Cortex A15 1.4GHz processor, has 2 Gigabytes of RAM, dual Gigabit Ethernet ports with Link Aggregation technology and delivers up to 200MByte/sec data transfer speed. It offers the industry’s leading feature of 5 levels of protection on your documents, photos, videos and all types of data. The ReadyCLOUD portal-based user interface and app on PC, Mac, smartphones and tablets make the RN210 the ideal choice for consumers because of its simplicity and ease of use.
Product Description | NETGEAR ReadyNAS 212 - NAS server - 6 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 6 TB | Max Supported Capacity | 12 TB | Installed Devices / Modules Qty | 2 (installed) / 2 (max) | Dimensions (WxDxH) | 22 cm x 10.1 cm x 14.2 cm | Weight | 2.03 kg () | Processor | 1 x Cortex-A15 1.4 GHz (Dual-Core) | Storage Controller | 1 x RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Hard Drive | 2 x 3 TB | Networking | 10Mb LAN, 100Mb LAN, GigE | RAM | 2 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | ReadyNAS OS 6.2 | System Requirements | UNIX, Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Android, Microsoft Windows 7 (32/64 bits), Apple iOS, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits) | Manufacturer Warranty | 3-year warranty |
General | |
Width | 22 cm |
Depth | 10.1 cm |
Height | 14.2 cm |
Processor / Memory | |
Processors Installed | 1 x Cortex-A15 1.4 GHz |
Number of Cores | Dual-Core |
RAM | 2 GB |
Flash Memory Installed | 128 MB |
Storage Controller | |
Type | 1 x RAID |
Interface Type | SATA 3Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Hard Drive | |
Type | HDD |
Capacity | 2 x 3 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | TCP/IP, NTP, FTP, DHCP, Bonjour, SMB |
Remote Management Protocol | SNMP 2, SNMP 3, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS |
Features | Wake on LAN (WOL), E-mail alert, IPv6 support, Access Control List (ACL) support, SSH support, Jumbo Frames support, static IP mode, IPv4 support, dynamic IP mode, DHCP client, WebDAV server, Dropbox support, anti-virus protection |
Encryption Algorithm | 256-bit AES |
Compliant Standards | IEEE 802.3ad (LACP), UPnP |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Interfaces | 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 , 1 x eSATA |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), X-RAID2 technology, LED indicator, built-in cooling fan, UPS support, auto shutdown circuit, VPN support, one-touch copy button |
Compliant Standards | FCC Class B certified, RoHS, AES-256, VCCI Class B |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 60 Watt |
Software / System Requirements | |
OS Required | UNIX, Apple MacOS, Linux, Microsoft Windows Server 2008 R2, Android, Microsoft Windows 7 (32/64 bits), Apple iOS, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
