We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Ideal for multi-service, multi-tenant data center providers; virtual machine backup; disaster recovery backup target, and IP surveillance camera video storage, NETGEAR RR4360X is high-density 60-bay 10GbE rackmount network storage system for small and medium size business, expandable to 132 drive bays and over 1 Petabyte of data storage and backup. With 5 levels of unrivaled data protection, ReadyCLOUD flexible file sharing and ReadyDR backup and disaster recovery, the RR4360X network storage offers outstanding performance and scalability with low Total Cost of Ownership (TCO) and easy management! The RR4360X is housed in a space-efficient 4U chassis, offering 60-bay SAS or SATA III HDD storage capacity.
Product Description | NETGEAR ReadyNAS RR4360X - NAS server | Device Type | NAS server | Host Connectivity | 10 Gigabit Ethernet | Enclosure Type | Rack-mountable - 4U | Max Supported Capacity | 120 TB | Dimensions (WxDxH) | 44.5 cm x 92.2 cm x 17.5 cm | Weight | 33.2 kg () | Processor | 1 x Intel Xeon E3-1225V5 3.3 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, JBOD, 60 | Networking | 10Mb LAN, 100Mb LAN, 1GbE, 10GbE | RAM | 16 GB | Power | AC 120/230 V (50/60 Hz) | System Requirements | UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Android, Apple iOS, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016 | Manufacturer Warranty | 5-year warranty |
General | |
Width | 44.5 cm |
Depth | 92.2 cm |
Height | 17.5 cm |
Processor / Memory | |
Processors Installed | 1 x Intel Xeon E3-1225V5 3.3 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
Max Turbo Speed | 3.7 GHz |
RAM | 16 GB (installed) / 64 GB (supported) - DDR4 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60 |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE, 10GbE |
Network / Transport Protocol | TCP/IP, NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB |
Remote Management Protocol | SNMP 2, SNMP 3, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV) |
Features | Hardware encryption, wake on LAN (WOL), E-mail alert, IPv6 support, file sharing, event log, Access Control List (ACL) support, iTunes server, Jumbo Frames support, static IP mode, Thin Provisioning, ReadySHARE, IPv4 support, DLNA Media Server, Apple Time Machine compatible, dynamic IP mode, DHCP client, cloud managed, Dropbox support, 5 fans, automated backup scheduling, anti-virus protection, Link Aggregation, Amazon Cloud Drive support, ReadyCLOUD, Bit Rot Protection, DLNA support, multiple IP settings |
Encryption Algorithm | SSL, TLS, 256-bit AES |
Compliant Standards | IEEE 802.3ad (LACP), DLNA CERTIFIED, UPnP |
Expansion / Connectivity | |
Expansion Bays | 60 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Interfaces | 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x eSATA , 2 x Ethernet 10Gb - RJ-45 , 3 x - external mini-SAS (SFF 8088) |
Miscellaneous | |
Features | UPS support, firmware upgradable, auto shutdown circuit, VPN support, X-RAID technology |
Compliant Standards | RoHS, VCCI Class A |
Power | |
Power Device | Internal power supply |
Installed Qty | 2 |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 700 Watt |
Software / System Requirements | |
Software Included | VMware vSphere 6.0 |
OS Required | UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Android, Apple iOS, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016 |
Manufacturer Warranty | |
Service & Support | Limited warranty - replacement - 5 years - response time: next business day |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
