Nintendo Switch Lite is a compact, lightweight Nintendo Switch system dedicated to handheld play. With a built-in +Control Pad and a sleek, unibody design, it's great for on-the-go gaming. Nintendo Switch Lite is compatible with the robust library of Nintendo Switch games that support handheld mode. If you're looking for a gaming system all your own, Nintendo Switch Lite is ready to hit the road whenever you are.
Got an old games console lying around?
When you trade in your old device you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Nintendo Switch Lite - Zacian and Zamazenta Edition - handheld game console - cyan, magenta | Product Type | Handheld game console | Display | 5.5" colour - 1280 x 720 - touch screen | Sensors | Accelerometer, gyro sensor | Media | Flash memory card, Nintendo Switch Game Card | Supported Flash Memory Cards | microSD, microSDHC, microSDXC | Network | Near Field Communication (NFC), Wi-Fi, Bluetooth 4.1 | Battery | Lithium Ion - 3570 mAh | Colour | Cyan, magenta | Dimensions (WxDxH) | 20.8 cm x 1.39 cm x 9.11 cm | Weight | 275 g | Included Accessories | AC power adapter |
General | |
Processor | NVIDIA Tegra |
Flash Memory | 32 GB |
Sound | Speakers |
Network | Near Field Communication (NFC), 802.11a/b/g/n/ac, Bluetooth 4.1 |
Features | Volume control |
Parental Control Capability | Yes |
Width | 20.8 cm |
Depth | 1.39 cm |
Height | 9.11 cm |
Weight | 275 g |
Display | |
Type | LCD display 5.5" colour |
Resolution | 1280 x 720 |
Touch Screen | Yes |
Controller | |
Controls | A button, B button, L Button, R Button, cross control pad, Minus button, Plus button, Home button, X button, Y button, ZL button, ZR button, Right stick, Left stick, Capture button |
Interfaces | |
Connector Type | USB , Audio line-out |
Slots | 1 x Nintendo Switch Game Card slot |
Miscellaneous | |
Battery | Rechargeable Lithium Ion - 3570 mAh |
Run Time (Up To) | 7 hour(s) |
