Nokia 3.1
Your premium companion
A design worth treasuring
The new Nokia 3 looks and feels premium. It draws attention with its subtle curves and striking diamond-cut aluminium sides. And with its curved back and sculpted Corning® Gorilla® Glass display, the new Nokia 3 nestles comfortably in your hand.
The perfect screen ratio
A compact device with maximized screen space. The 18:9 ratio in the new Nokia 3 is perfect for getting the most out of its 5.2’’ HD+ display whether you’re watching films or feeds – no more missed screen space.
Sharper, more detailed photos
The 13 MP auto-focus rear camera with LED flash let you capture crisp photos whether you’re out and about or indoors. And the 8 MP front camera with a wide 84.6-degree field of view is perfect for taking group selfies.
The best apps at your fingertips
The powerful Octa-Core processor in the new Nokia 3 lets you experience more, whether you’re playing AR games or multitasking between apps. You’ll also enjoy secure access to useful apps like Google Pay.
The best of Android™, latest innovation from Google
Android One brings a Google designed software experience to the new Nokia 3. Get everything you want and nothing you don’t with a streamlined, easy to use interface and a curated set of pre-installed apps, and free, unlimited high quality photos storage?with Google Photos. Regular security updates and two years of OS upgrades means the new Nokia 3 with Android One stays secure and features the latest Google innovations like being optimized for the Google Assistant.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Nokia 3.1 - Android One - blue/copper - 4G smartphone - 16 GB - GSM | Product Type | 4G smartphone | Display | LCD display - 5.2" - 18:9 - Corning Gorilla Glass (scratch resistant glass) | Processor | MediaTek MT6750N / 1.5 GHz (8-core) - 64-bit | Memory | RAM 2 GB / 16 GB | Supported Memory Card | microSDXC slot - up to 128 GB | Operating System | Android 8.0 Oreo | Main Camera | 13 Megapixel - wide-angle lens - f/2.0 - focus: automatic | Front Camera | 8 Megapixel f/2.2 - focus free | Service Provider | Not specified | SIM Card | Dual-SIM | Wireless Interface | Wi-Fi 5, Bluetooth | Messaging Services | SMS, MMS | Connectors | 3.5 mm headset jack, USB-C | Colour | Blue/copper | Dimensions (WxDxH) | 68.65 mm x 8.7 mm x 146.25 mm | Weight | 138.3 g | Specific Absorption Rate (SAR) | 0.64 W/kg (head) , 1.63 W/kg (body) , 3.99 W/kg (limb) |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Width | 68.65 mm |
Depth | 8.7 mm |
Height | 146.25 mm |
Weight | 138.3 g |
Body Colour | Blue/copper |
SAR Value | 1.63 W/kg (body), 0.64 W/kg (head), 3.99 W/kg (limb) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Navigation | GPS, A-GPS, GLONASS, BeiDou |
SIM Card Qty | Dual-SIM |
Input Device | Multi-touch, capacitive |
Messaging & Internet | |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE |
Wireless Interface | IEEE 802.11a/b/g/n/ac, Bluetooth 4.2 |
Phone Features | |
Phone Functions | Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert |
Sensors | Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor |
Processor | |
Type | MediaTek |
Processor Number | MT6750N |
Clock Speed | 1.5 GHz |
Processor Core Qty | 8-core |
64-bit Architecture | Yes |
Memory | |
RAM | 2 GB |
Internal Memory Capacity | 16 GB |
Supported Flash Memory Cards | microSDHC, microSDXC - up to 128 GB |
Front Camera | |
Sensor Resolution | 8 Megapixel |
Lens Aperture | F/2.2 |
Focus Adjustment | Focus free |
Main Camera | |
Sensor Resolution | 13 Megapixel |
Lens Type | Wide-angle lens |
Lens Aperture | F/2.0 |
Focus Adjustment | Automatic |
Light Source | LED flash |
Display | |
Type | LCD display |
Diagonal Size | 5.2" |
Display Format | HD+ |
Aspect Ratio | 18:9 |
Protection | Corning Gorilla Glass (scratch resistant glass) |
Connections | |
Connector Type | Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm |
Battery | |
Capacity | 2990 mAh |
Miscellaneous | |
Included Accessories | USB cable, power adapter, SIM card removal tool |
