The Nokia 8 undergoes a rigorous 40-stage process of machining, anodizing and polishing to ensure its distinctive design pairs flawlessly with the polished aluminum unibody. The ultimate in seamless unibody construction, Nokia 8 is designed to nestle perfectly in the palm of your hand.
A first for mobile phones, the exclusive Dual-Sight mode lets you use both front and back cameras simultaneously for split-screen photos and video.
Nokia 8 features a 13 MP dual image-fusion rear camera with both color and monochrome sensors, plus a wide-angle 13 MP phase detection auto-focus front camera. Both front and rear cameras are equipped with ZEISS optics, meaning every snapshot moment becomes a story worth sharing.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Nokia 8 - steel - 4G smartphone - 64 GB - GSM | Product Type | 4G smartphone | Display | LCD display - 2560 x 1440 pixels - 5.3" - IPS - Corning Gorilla Glass 5 (scratch resistant glass) | Processor | Qualcomm Snapdragon 835 2.5 GHz (8-core) - 64-bit | Memory | RAM 4 GB / 64 GB | Supported Memory Card | microSDXC slot - up to 256 GB | Operating System | Android 7.1.1 Nougat | Main Camera | 13 Megapixel - f/2.0 - focus: automatic laser auto focus: - laser focus | Second Camera | 13 Megapixel | Front Camera | 13 Megapixel - wide-angle lens - f/2.0 - automatic | Service Provider | Not specified | SIM Card | Dual-SIM (SIM1 and SIM2/MicroSD slots) - nano SIM | Wireless Interface | NFC, Wi-Fi 5, Bluetooth, ANT+/ANT | Security Devices | Fingerprint reader | Messaging Services | SMS, MMS | Connectors | 3.5 mm headset jack, USB-C | Protection | Splashproof | Colour | Steel | Dimensions (WxDxH) | 73.7 mm x 7.9 mm x 151.5 mm | Specific Absorption Rate (SAR) | 0.711 W/kg (head) , 1.33 W/kg (body) , 3.99 W/kg (limb) |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Width | 73.7 mm |
Depth | 7.9 mm |
Height | 151.5 mm |
Body Colour | Steel |
Body Material | 6000 Series aluminium alloy |
SAR Value | 1.33 W/kg (body), 0.711 W/kg (head), 3.99 W/kg (limb) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Intelligent Assistant | Google Assistant |
Navigation | GPS, A-GPS, GLONASS, BeiDou |
SIM Card Type | Nano SIM |
SIM Card Qty | Dual-SIM (SIM1 and SIM2/MicroSD slots) |
SIM Card Configuration Details | Nano SIM + nano SIM/microSD |
Input Device | Multi-touch, capacitive |
Messaging & Internet | |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE |
Wireless Interface | NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0, ANT+/ANT |
Phone Features | |
Phone Functions | Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert |
Sensors | Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor, hall sensor |
Android Enterprise Recommended | Yes |
Additional Features | MIMO technology, Three microphones, Nokia OZO spatial 360° audio |
Processor | |
Type | Qualcomm Snapdragon 835 |
Clock Speed | 2.5 GHz |
Processor Core Qty | 8-core |
64-bit Architecture | Yes |
Memory | |
RAM | LPDDR4X SDRAM - 4 GB |
Internal Memory Capacity | 64 GB |
Supported Flash Memory Cards | microSDHC, microSDXC - up to 256 GB |
Front Camera | |
Sensor Resolution | 13 Megapixel |
Lens Type | Wide-angle lens |
Lens Aperture | F/2.0 |
Focus Adjustment | Automatic |
Video Resolutions | 3840 x 2160 (4K) |
Light Source | Display flash |
Features | Phase Detect Auto-Focus (PDAF) |
Main Camera | |
Optical Image Stabiliser | Optical Image Stabiliser (OIS) |
Laser Auto Focus | Yes |
Light Source | Dual LED flash |
Features | Carl Zeiss optic, Phase Detect Auto-Focus (PDAF), Dual-tone Flash, IR range finder, Dual-Sight mode |
Second Camera | |
Display | |
Type | LCD display |
Technology | IPS |
Diagonal Size | 5.3" |
Display Resolution | 2560 x 1440 pixels |
Display Format | QHD |
Protection | Corning Gorilla Glass 5 (scratch resistant glass) |
Features | 2.5D Glass |
Connections | |
Connector Type | USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm |
Battery | |
Capacity | 3090 mAh |
Miscellaneous | |
Compliant Standards | IP54 |
Included Accessories | Data cable, headset, power adapter, SIM card removal tool |
