Nokia 8 Sirocco
Ordinary life deserves an extraordinary phone.
The Nokia 8 Sirocco is carved out of a single piece of stainless steel, machined for hours into a solid, yet uniquely slim and compact shape. Elegantly tailored to fit even those not-so-elegantly tailored trousers.
Full 3D Corning® Gorilla® Glass 5 curves around all sides to provide real beauty you can see and feel.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Nokia 8 Sirocco - Android One - black - 4G smartphone - 128 GB - GSM | Product Type | 4G smartphone | Display | OLED display - 5.5" - P-OLED - Corning Gorilla Glass 5 (scratch resistant glass) | Processor | Qualcomm Snapdragon 835 2.36 GHz (8-core) - 64-bit | Memory | RAM 6 GB / 128 GB | Operating System | Android 8.0 Oreo | Main Camera | 12 Megapixel - wide-angle lens - 2x optical zoom - f/1.7 - focus: automatic | Second Camera | 13 Megapixel - telephoto lens - f/2.6 | Front Camera | 5 Megapixel | Service Provider | Not specified | SIM Card | Single-SIM | Wireless Interface | NFC, Wi-Fi 5, Bluetooth, ANT+/ANT | Security Devices | Fingerprint reader | Messaging Services | SMS, MMS | Connectors | USB-C | Wireless Charging Standards | Qi | Protection | Dustproof, water-resistant | Colour | Black | Dimensions (WxDxH) | 72.97 mm x 7.5 mm x 140.93 mm | Specific Absorption Rate (SAR) | 0.59 W/kg (head) , 1.54 W/kg (body) , 3.99 W/kg (limb) |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Width | 72.97 mm |
Depth | 7.5 mm |
Height | 140.93 mm |
Body Colour | Black |
SAR Value | 1.54 W/kg (body), 0.59 W/kg (head), 3.99 W/kg (limb) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Intelligent Assistant | Google Assistant |
Navigation | GPS, A-GPS, GLONASS, BeiDou |
SIM Card Qty | Single-SIM |
Input Device | Multi-touch |
Messaging & Internet | |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE |
Wireless Interface | NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0, ANT+/ANT |
Phone Features | |
Phone Functions | Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert |
Sensors | Ambient light sensor, digital compass, barometer, gyro sensor, G-sensor, hall sensor |
Android Enterprise Recommended | Yes |
Additional Features | MIMO technology, Smart AMP technology, Three AOP microphones |
Processor | |
Type | Qualcomm Snapdragon 835 |
Clock Speed | 2.36 GHz |
Processor Core Qty | 8-core |
64-bit Architecture | Yes |
Memory | |
RAM | LPDDR4X SDRAM - 6 GB |
Internal Memory Capacity | 128 GB |
Front Camera | |
Sensor Resolution | 5 Megapixel |
Light Source | Display flash |
Main Camera | |
Sensor Resolution | 12 Megapixel |
Lens Type | Wide-angle lens |
Lens Aperture | F/1.7 |
Focus Adjustment | Automatic |
Optical Zoom | 2x |
Camera Modes | Pro Camera mode |
Light Source | Dual tone LED flash |
Features | Carl Zeiss optic, Dual Phase Detect Auto-Focus (PDAF) |
Second Camera | |
Sensor Resolution | 13 Megapixel |
Lens Type | Telephoto lens |
Lens Aperture | F/2.6 |
Display | |
Type | OLED display |
Technology | P-OLED |
Diagonal Size | 5.5" |
Display Format | QHD |
Protection | Corning Gorilla Glass 5 (scratch resistant glass) |
Features | 3D Glass |
Connections | |
Connector Type | USB Type-C - 24 pin USB-C |
Battery | |
Capacity | 3260 mAh |
Wireless Charging | Yes |
Miscellaneous | |
Compliant Standards | IP67 |
Included Accessories | Protective cover, power adapter, SIM card removal tool, charging/data cable (A-C), audio adapter, USB-C wired headset |
