Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
Philips 241B8QJEB 24" 1920x1080 5ms DVI HDMI LED Monitor
£167.65
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • IPS technology for full colors and wide viewing angles
  • 16:9 Full HD display for crisp detailed images
  • SmartImage presets for easy optimized image settings
  • LowBlue Mode for easy-on-the-eye productivity
  • Less eye fatigue with Flicker-free technology
  • SmartErgoBase enables people-friendly ergonomic adjustments
  • Diagonal Size: 24in, 23-25 inches
  • Max Resolution: 1920 x 1080, Widescreen
  • Response Time: 5ms, 4-8ms
  • Speakers: Speaker(s), Speakers
  • Interfaces: HDMI, DVI, VGA (HD-15), DisplayPort + 1 more
Product codes
chevron icon
chevron icon
Get your best work done with the Philips 24" Full HD monitor. Crisp and vivid Full HD gives you the space and clarity to see your work. Features like height-adjustment, Flicker-free and LowBlue mode make work easy on the eyes.
chevron icon
Product Description Philips B Line 241B8QJEB - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class D
Energy Consumption per Year 26 kWh
Power Consumption (On mode) 14 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch 0.275 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 50000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Colour Gamut 103.8% sRGB, 89.9% NTSC
Input Connectors HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating, Haze 25%
Voltage AC 120/230 V (50/60 Hz)
Colour Black texture
Dimensions (WxDxH) - with stand 54 cm x 20.6 cm x 50.8 cm
Weight 4.97 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SEMKO, CB, TUV Ergo, PSB, DDC/CI, RoHS, WEEE, PSE Mark, MEPS, J-MOSS, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.2
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£167.65
