Directing its light in triangular light effects both up and down, the Resonate wall light in black allows you to illuminate your porches and patios with elegant, colourful light.
Product Description | Philips Hue White and Color Ambiance Resonate - wall lamp - LED x 2 - 8 W - 16 million colours/warm to cool white light - 2000-6500 K - black (pack of 2) | Product Type | Wall lamp | Recommended For | Garden, patio | Light Source Type | 2 x LED | Packaged Quantity | 2 (specifications are for single item) | Dimmer | Yes | Colour | Black | Wattage | 8 W | Colour of Illumination | 16 million colours/warm to cool white light | Colour Temperature | 2000-6500 K | Luminous Power | 1180 lumens | Intelligent Assistant | Siri, Google Assistant, Alexa - indirect | Platform | Hue | Voltage Required | AC 220 - 240 V | Frequency Required | 50 - 60 Hz |
General | |
Supported Light Bulb Wattage | 8 W |
Dimmer | Yes |
Waterproof | Yes |
Features | Weatherproof, outdoor usage, splashproof, protection class I, Android compatible, iOS compatible, app-controlled |
Light Source | |
Type | 2 x LED |
Built-in LED Lamp | Yes |
Wattage | 8 W |
Colour Rendering Index | 80 |
Lifetime | 25000 hours |
Power Requirements | |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub Compatibility | Philips Hue Bridge |
Platform | Hue |
Compatible Application | Philips Hue App |
Intelligent Assistant | Siri, Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Product Material | Die-cast aluminium |
Body Colour | Black |
Compliant Standards | IP44 |
Warranty | 2 years |
Dimensions & Weight | |
Width | 9.3 cm |
Depth | 12 cm |
Height | 18 cm |
Weight | 950 g |
Customer return - item has been opened but is in excellent condition
Ref: H4XG 048606 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£202.83
