The new Plantronics Blackwire 315 USB headsets are a simple-to-use, comfortable, and durable option for organizations seeking high-quality, entry-level UC devices. With outstanding audio quality, flexibility with choice of USB or 3.5mm connectivity, and comfortable leatherette ear cushions and lightweight headbands, they deliver top-notch features - and bottom-line value.
Product Description | Poly Blackwire 315 - headset | Product Type | Headset - wired - USB | Additional Functions | DSP | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Mono | Microphone | Boom | Controls | Mute, volume, answer/end |
General | |
Series | 300 Series |
Headband Material | Metal |
Audio Output | |
In-Cord Volume Control | Yes |
Microphone | |
Type | Boom |
Remote Control | |
Connections | |
Connector Type | USB (4 PIN USB Type A) |
Cable | |
Cable Length | 2.13 m |
Miscellaneous | |
Cable Details | Headset cable - 2.13 m |
