The new Plantronics Blackwire 325 USB headsets are a simple-to-use, comfortable, and durable option for organizations seeking high-quality, entry-level UC devices. With outstanding audio quality, flexibility with choice of USB or 3.5mm connectivity, and comfortable leatherette ear cushions and lightweight headbands, they deliver top-notch features - and bottom-line value.
Product Description | Poly Blackwire 325 - headset | Product Type | Headset - wired - USB, 3.5 mm jack | Additional Functions | DSP | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz | Microphone | Boom | Controls | Mute, volume, answer/end | Manufacturer Warranty | 2-year warranty |
General | |
Series | 300 Series |
Headband Material | Metal |
Audio Output | |
Frequency Response | 20 - 20000 Hz |
In-Cord Volume Control | Yes |
Features | SoundGuard Technology |
Microphone | |
Type | Boom |
Frequency Response | 100 - 10000 Hz |
Remote Control | |
Connections | |
Connector Type | USB (4 PIN USB Type A) , Headphones (mini-phone 3.5 mm 4-pole) |
Cable | |
Cable Length | 2.13 m |
Miscellaneous | |
Cable Details | Headset cable - 2.13 m |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
