Enjoy your mobile calls and hear streaming music and GPS directions without holding your phone or getting tangled in wired earbuds. The lightweight Plantronics Explorer 50 Bluetooth headset fits comfortably and is easy to set up, connecting to two smartphones so you can answer calls from either one. It hibernates to conserve power and even tells you when it's time to recharge.
Product Description | Poly - Plantronics Explorer 50 - headset | Product Type | Headset - Bluetooth - wireless | Recommended Use | Portable electronics | Headphones Form Factor | Ear-bud - over-the-ear mount | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Bluetooth Version | Bluetooth 3.0 | Sound Output Mode | Mono | Microphone | Built-in | Controls | Answer/end |
General | |
Weight | 11 g |
Audio Output | |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP) |
Remote Control | |
Miscellaneous | |
Cable Details | Micro-USB charge cable |
Power | |
Battery | Headset battery rechargeable |
Run Time (Up To) | 11 hour(s) |
