BackBeat Pro 2 wireless headphones shape the sounds of your day with on-demand active noise canceling, wireless freedom, and immersive audio.
Product Description | Poly - Plantronics Backbeat Pro 2 - headphones with mic | Product Type | Headphones - Bluetooth - wireless | Recommended Use | Portable electronics | Colour | Black | Image Colour Disclaimer | The displayed product image may be a different colour | Headphones Form Factor | On-ear | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Bluetooth Version | Bluetooth 4.0 EDR | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 93 dB | Impedance | 32 Ohm | Active Noise Canceling | Yes | Controls | Volume, answer/end, play/pause, next/previous track |
General | |
Weight | 289 g |
Colour | Black |
Max Operating Distance | 100 m |
Audio Output | |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 93 dB |
Diaphragm | 40 mm |
Microphone | |
Form Factor | Built-in |
Remote Control | |
Wireless Link | |
Transmission Range | 100 m |
Connections | |
Connector Type | Headphones (mini-phone stereo 3.5 mm 4-pole) |
Miscellaneous | |
Included Accessories | Travel pouch |
Cable Details | USB charge cable , Headphones cable |
Power | |
Battery | Headphone battery rechargeable - Lithium Ion |
Run Time (Up To) | 24 hour(s) |
Recharge Time | 3 hours |
