Keep the Plantronics Voyager Legend charged on the go with the pocket-sized charging case, the perfect accessory for storing, protecting, and recharging your headset. The case's internal battery can recharge the Voyager Legend headset twice for up to 14 hours of additional talk time. LED indicators show the battery status of both the headset and the case at a glance. Case recharges from any micro USB charge cable.
Product Description | Poly Charging Case external battery pack | Product Type | External battery pack | Cables | USB charge cable - 61 cm | Talk Time | Up to 1260 min | Designed For | Voyager Legend, Legend UC, Legend UC B235, Legend UC B235-M |
General | |
Power Device | |
Input Connectors | 5 pin Micro-USB Type B |
Input Connectors Qty | 1 |
Battery | |
Features | LED power meter |
Miscellaneous | |
Cables Included | USB charge cable - 61 cm |
Compatibility Information | |
Designed For | Poly Voyager Legend, Legend UC, Legend UC B235, Legend UC B235-M |
