Never worry about the quality of recorded video Full HD definition of Prestigio Roadrunner CUBE camera ensures that every single detail will be visible and you can be confident about your safety on the road. If an accident occurs you will get all the evidence of your innocence.
Product Description | Prestigio Roadrunner CUBE - dashboard camera | Product Type | Dashboard camera - 1080p | Memory Card Slot | SD card | Image Processor | MSC8328P | Sensors | G-sensor | Wireless Interface | Wireless LAN | Sensor Resolution | 2.0 MP | Effective Sensor Resolution | Photo: 2.0 MP | Max Video Resolution | 1920 x 1080 | Lens System | Wide-angle lens | Focus Adjustment | Focus free | Display | LCD display - 1.5" | Incident Detection | G-Sensor | Supported Battery | Li-Polymer rechargeable battery - 150 mAh (included) | Interface | USB 2.0 | Colour | Black | Dimensions (WxDxH) | 4.5 cm x 4.4 cm x 4.5 cm | Weight | 72 g | Manufacturer Warranty | 1-year warranty |
General | |
Enclosure Colour | Black |
Camcorder Sensor Resolution | 2.0 MP |
Sensor Qty | 1 CMOS |
Effective Photo Resolution | 2.0 MP |
Widescreen Video Capture | Yes |
Optical Sensor Type | CMOS |
Optical Sensor Size | 1/2.9" |
Frame Rate (Max Resolution) | 30 fps |
Digital Video Format | H.264 |
Image Recording Format | JPEG |
Interface | USB 2.0, Wireless LAN |
Connectivity Features | Remote control via mobile devices, remote live view |
Exposure & White Balance | |
Exposure Modes | Automatic |
White Balance | Automatic |
Lens System | |
Type | Wide-angle lens - wide angle |
Max View Angle | 140 degree(s) |
Additional Features | |
Additional Features | Audio recording, built-in speaker, Motion Detection Technology, overheat protection |
Dashboard Camera Features | |
Features | Loop recording |
Display | |
Type | 1.5" LCD display |
Display Format | 480 x 240 |
Display Form Factor | Built-in |
Microphone | |
Microphone Operation Mode | Mono |
Connections | |
Connector Type | USB 2.0 (5 pin Micro-USB Type B) |
Miscellaneous | |
Included Accessories | Car power adapter, USB cable, adhesive mount |
Body Material | Plastic, metal |
Battery | |
Battery Type | Lithium polymer - integrated |
Details | Li-Polymer rechargeable battery - 150 mAh (included) |
Memory / Storage | |
Supported Memory Cards | SD Memory Card, SDHC Memory Card |
Memory Card Included | No |
Memory Card Max Supported Size | 32 GB |
Video Capture | H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight | |
Width | 4.5 cm |
Depth | 4.4 cm |
Height | 4.5 cm |
Weight | 72 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
