The TS-453Be features a simple physical design that can easily fit into office and home environments. It provides a PCIe port that can boost its functionality. The TS-453Be also supports dual-channel 4K H.264/H.265 processing to provide a smooth media viewing experience on all connected devices.
Product Description | QNAP TS-453Be-4G - NAS server | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Installed Devices / Modules Qty | 0 (installed) / 4 (max) | Dimensions (WxDxH) | 17 cm x 22.6 cm x 16.8 cm | Weight | 2.33 kg () | Processor | 1 x Intel Celeron J3455 1.5 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Networking | 10Mb LAN, 100Mb LAN, 1GbE | RAM | 4 GB | Power | AC 120/230 V | Storage Operating System | QNAP QTS 4.3.4 | System Requirements | UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016 |
General | |
Total Storage Capacity | 0 GB |
Width | 17 cm |
Depth | 22.6 cm |
Height | 16.8 cm |
Built-in Devices | Led panel |
Processor / Memory | |
Processors Installed | 1 x Intel Celeron J3455 1.5 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
Max Turbo Speed | 2.3 GHz |
RAM | 4 GB (installed) / 8 GB (supported) - DDR3L |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE |
Network / Transport Protocol | TCP/IP, PPTP, L2TP, IPSec, FTP, DHCP, DDNS |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV) |
Features | Wake on LAN (WOL), iTunes server, Jumbo Frames support, DHCP server, FTP server, teaming support, DLNA Media Server, DHCP client, 4K resolution support, VPN Server, VPN client, port trunking, FXP support, RTRR server, RTRR client |
Encryption Algorithm | SSL, FIPS 140-2, 256-bit AES, AES-NI |
Compliant Standards | DLNA CERTIFIED |
Security DVR | |
Compression Format | H.264, H.265 |
Expansion / Connectivity | |
Expansion Bays | 4 (total) / 4 (free) x hot-swap - 2.5" / 3.5" |
Expansion Slots | 1 (total) / 1 (free) x PCI Express 2.0 x2 |
Interfaces | 2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 3.0 - Type A , 2 x microphone - mini-jack , 2 x HDMI output - Type A , 1 x audio out - mini-jack |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), built-in cooling fan |
Security Slot Type | Kensington security slot |
Included Accessories | Screws |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 30.04 Watt |
Power Provided | 90 Watt |
Software / System Requirements | |
OS Required | UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
