The powerful 8-bay, quad-core TS-832X includes two 10GbE SFP+ ports to fully support 10GbE high-speed networks at a budget price with maximized ROI. It is also an ARM-based NAS that supports Qtier technology for efficient auto-tiered storage. The PCIe slots extend greater application potential, for example, by installing QNAP's new PCIe wireless network card QWA-AC2600 the TS-832X is transformed into a convenient wireless base station that allows devices to directly connect to the NAS for easy access to its services and Internet connection.
Product Description | QNAP TS-832X - NAS server | Device Type | NAS server | Host Connectivity | Gigabit Ethernet / 10 Gigabit Ethernet | Installed Devices / Modules Qty | 0 (installed) / 8 (max) | Dimensions (WxDxH) | 32.93 cm x 27.96 cm x 18.82 cm | Weight | 6.52 kg () | Processor | 1 x Annapurna Labs Alpine AL-324 1.7 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, JBOD, 60 | Networking | 10Mb LAN, 100Mb LAN, 1GbE, 10GbE | IP Cameras Supported | 24 | RAM | 8 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | QNAP QTS 4.3.4 | System Requirements | UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016 |
General | |
Total Storage Capacity | 0 GB |
Width | 32.93 cm |
Depth | 27.96 cm |
Height | 18.82 cm |
Built-in Devices | Speaker, led panel |
Processor / Memory | |
Processors Installed | 1 x Annapurna Labs Alpine AL-324 1.7 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
RAM | 8 GB (installed) / 16 GB (supported) - DDR4 |
Flash Memory Installed | 512 MB |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60 |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE, 10GbE |
Network / Transport Protocol | TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS, SFTP, SMSC |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, SFTP |
Network Services Compatibility | Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP |
Features | Hardware encryption, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, DHCP server, FTP server, SMS alert, BitTorrent Client, reset button, bandwidth control, IPv4 support, surveillance station, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SNMP support, Apple AirPlay, Dropbox support, Wi-Fi USB dongle support, Real-time Remote Replication (RTRR), Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, Chromecast support, hubiC support, OpenStack Swift-compatible, USB One Touch Copy, Microsoft Azure support, Amazon S3 support, Amazon Glacier suport, HiDrive support, FXP support, RTRR server, RTRR client |
Encryption Algorithm | SSL, TLS, FIPS 140-2, 256-bit AES |
Compliant Standards | UPnP |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" |
Expansion Slots | 1 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x PCI Express 2.0 , 1 (total) / 1 (free) x PCI Express 2.0 x2 |
Interfaces | 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x audio out - mini-jack , 2 x Ethernet 10Gb - SFP+ |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), audible alarm, wake on LAN, built-in 2 cooling fans, scheduled power on/off |
Security Slot Type | Kensington security slot |
Compliant Standards | FIPS 140-2, AES-256 |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 250 Watt |
Software / System Requirements | |
OS Required | UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
