The TS-963X is an affordable NAS for small and medium-sized businesses (SMBs) with AMD Embedded G-Series GX-420MC quad-core 2.0 GHz processor, 9 drive bays and a built-in 5-speed 10GBASE-T port for up to 10Gb connectivity. Four 2.5-inch drive bays can be used to install SSDs to enable caching and Qtier technology. One built-in 5-speed 10GBASE-T port (10G/5G/2.5G/1G/100M) also increases productivity of businesses with existing Cat 5e/6 cables, without extra costs or additional installation procedures. Combined with several QNAP technologies including VJBOD, Container Station, and Virtualization Station, the TS-963X has the potential to empower a wide range of business applications and can also be easily expanded to fit future data storage requirements.
Product Description | QNAP TS-963X - NAS server | Device Type | NAS server | Host Connectivity | Gigabit Ethernet / 10 Gigabit Ethernet | Installed Devices / Modules Qty | 0 (installed) / 9 (max) | Dimensions (WxDxH) | 32.93 cm x 27.96 cm x 18.82 cm | Weight | 3.53 kg () | Processor | 1 x AMD G-series Embedded GX-420MC 2 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, JBOD, 60 | Networking | 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE | IP Cameras Supported | 3000 | RAM | 2 GB | Power | AC 120/230 V | Storage Operating System | QNAP QTS 4.3.4 | System Requirements | UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X Lion 10.7, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016 |
General | |
Total Storage Capacity | 0 GB |
Width | 32.93 cm |
Depth | 27.96 cm |
Height | 18.82 cm |
Processor / Memory | |
Processors Installed | 1 x AMD G-series Embedded GX-420MC 2 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
RAM | 2 GB (installed) / 16 GB (supported) - DDR3L |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60 |
Networking | |
Data Link Protocol | 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE |
Network / Transport Protocol | TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, SMB, DDNS |
Remote Management Protocol | SNMP 2, SNMP, Telnet, SNMP 3, HTTP, HTTPS, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), DHCP, DDNS, Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV) |
Features | NAT support, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, IPv6 support, firmware upgradable, proxy server, Spanning Tree Protocol (STP) support, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, Network Access Protection (NAP), bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, Dropbox support, Real-time Remote Replication (RTRR), Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support, DLNA support, file station, hubiC support, OpenStack Swift-compatible, WebDAV server support, port trunking, Microsoft Azure support, Amazon S3 support, Amazon Glacier suport, HiDrive support, RTRR server, RTRR client |
Encryption Algorithm | AES-NI |
Compliant Standards | UPnP |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 5 (total) / 5 (free) x hot-swap - 2.5" / 3.5" , 4 (total) / 4 (free) x hot-swap - 2.5" |
Expansion Slots | 2 (total) / 1 (free) x SO-DIMM 260-pin |
Interfaces | 1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x Ethernet 10Gb - RJ-45 , 2 x USB 2.0 - Type A , 1 x audio out - mini-jack |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), built-in cooling fan, built-in speaker |
Security Slot Type | Kensington security slot |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 53.06 Watt |
Power Consumption Stand by | 35.64 Watt |
Power Provided | 120 Watt |
Software / System Requirements | |
OS Required | UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X Lion 10.7, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Sound Emission | 17.3 dBA |
