Exclusively providing a Thunderbolt/NAS/iSCSI SAN triple solution, the TVS-1282T3 features four Thunderbolt 3 ports to enable seamless collaboration between up to four Mac and Windows devices. Coupled with its higher bandwidth to smooth Ultra HD video transfer and online editing, the TVS-1282T3 is a perfect match for Thunderbolt-equipped users for Ultra HD workflows, file storage and high-speed sharing.
Product Description | QNAP TVS-1282T3 - NAS server | Device Type | NAS server | Host Connectivity | 10 Gigabit Ethernet | Installed Devices / Modules Qty | 0 (installed) / 12 (max) | Dimensions (WxDxH) | 36.99 cm x 31.98 cm x 23.46 cm | Weight | 11.55 kg () | Processor | 1 x Intel Core i7 7700 3.6 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Networking | 10Mb LAN, 100Mb LAN, 1GbE, 10GbE | RAM | 32 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | QNAP QTS 4.2 | System Requirements | UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10 |
General | |
Total Storage Capacity | 0 GB |
Width | 36.99 cm |
Depth | 31.98 cm |
Height | 23.46 cm |
Built-in Devices | Stereo speakers, led panel |
Processor / Memory | |
Processors Installed | 1 x Intel Core i7 7700 3.6 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
RAM | 32 GB (installed) / 64 GB (supported) - DDR4 |
Flash Memory Installed | 512 MB |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE, 10GbE |
Network / Transport Protocol | TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP |
Features | LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, IPv6 support, Access Control List (ACL) support, DHCP server, SMS alert, reset button, IPv4 support, DHCP client, 4K resolution support, cloud backup, Real-time Remote Replication (RTRR) |
Encryption Algorithm | SSL, 128-bit AES, 256-bit AES |
Compliant Standards | DLNA CERTIFIED, UPnP |
Expansion / Connectivity | |
Expansion Bays | 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" , 4 (total) / 4 (free) x hot-swap - 2.5" |
Expansion Slots | 2 x PCI Express 3.0 x4 , 1 x PCI Express 3.0 x8 , 2 (total) / 2 (free) x M.2 |
Interfaces | 4 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb , 5 x USB 3.0 - Type A , 3 x HDMI output - Type A , 4 x Thunderbolt 3 , 1 x audio out - mini-jack , 2 x audio in - 6.3mm jack |
Miscellaneous | |
Cables Included | 6 x network cable |
Features | Built-in 3 cooling fans |
Compliant Standards | FIPS 140-2 |
Included Accessories | Mounting kit, remote control, 2 x M.2 SSD heatsink |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Software / System Requirements | |
OS Required | UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Sound Emission | 21.6 dB |
